example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.1.3 (from 27.1.3 RC2)
Operating system and version (eg, Ubuntu 20.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): 2.4.56
PHP version (eg, 7.4): 8.2
Failing to upgrade to 27.1.3 via web gui. Stuck on deleting old files
- Open update dialog from Admin settings
- Run through update
can't access. server stuck in update mode
'instanceid' => 'ocbnjkxht1xp',
'passwordsalt' => 'REMOVED',
'secret' => 'REMOVED',
0 => 'REMOVED',
1 => 'REMOVED',
'default_phone_region' => 'US',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '27.1.3.1',
'overwrite.cli.url' => 'REMOVED',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'REMOVED',
'twofactor_enforced' => 'true',
'app_install_overwrite' =>
0 => 'maps',
1 => 'duplicatefinder',
2 => 'richdocuments',
3 => 'gpxedit',
4 => 'documentserver_community',
'maintenance' => true,
'updater.release.channel' => 'beta',
'theme' => '',
'loglevel' => 2,
'memories.exiftool' => '/var/www/html/nextcloud/apps/memories/bin-ext/exiftool-amd64-glibc',
'memories.vod.path' => '/var/www/html/nextcloud/apps/memories/bin-ext/go-vod-amd64',
'mail_from_address' => 'postmaster',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'REMOVED',
'mail_smtphost' => '192.168.35.5',
'mail_smtpport' => '25',
'memcache.locking' => '\\OC\\Memcache\\APCu',
'mail_smtpauth' => 1,
'mail_smtpname' => 'REMOVED',
'mail_smtppassword' => 'REMOVED',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\Image',
1 => 'OC\\Preview\\HEIC',
2 => 'OC\\Preview\\TIFF',
3 => 'OC\\Preview\\Movie',
'memories.vod.disable' => false,
'memories.gis_type' => 1,
'updater.secret' => 'REMOVED,
[Fri Oct 27 12:11:36.350017 2023] [php:warn] [pid 1963] [client 192.168.35.1:47530] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:37.313125 2023] [php:warn] [pid 183] [client 192.168.35.1:47536] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:38.042508 2023] [php:warn] [pid 187] [client 192.168.35.1:47552] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:38.649659 2023] [php:warn] [pid 186] [client 192.168.35.1:47562] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:38.973678 2023] [php:warn] [pid 184] [client 192.168.35.1:47570] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:39.300176 2023] [php:warn] [pid 185] [client 192.168.35.1:47580] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:39.628413 2023] [php:warn] [pid 1963] [client 192.168.35.1:47594] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:11:39.988389 2023] [php:warn] [pid 183] [client 192.168.35.1:38258] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:13:05.909611 2023] [php:warn] [pid 184] [client 192.168.35.1:44226] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty/.git/objects/pack): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
[Fri Oct 27 12:30:14.359086 2023] [php:warn] [pid 1963] [client 192.168.35.1:52408] PHP Warning: rmdir(/var/www/html/nextcloud/updater/../3rdparty): Permission denied in /var/www/html/nextcloud/updater/index.php on line 927
{"reqId":"e3UkGwOtrQsaUF6ji2F2","level":3,"time":"2023-10-27T04:34:26+00:00","remoteAddr":"192.168.35.1","user":"Jeef","app":"no app in context","method":"GET","url":"/ocs/v2.php/apps/files_sharing/api/v1/shares?format=json&path=filename.jpg&shared_with_me=true","message":"$absolutePath must be relative to \"files\", value is \"/\"","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"27.1.3.1","data":[]}
{"reqId":"e3UkGwOtrQsaUF6ji2F2","level":3,"time":"2023-10-27T04:34:26+00:00","remoteAddr":"192.168.35.1","user":"Jeef","app":"no app in context","method":"GET","url":"/ocs/v2.php/apps/files_sharing/api/v1/shares?format=json&path=%2Flespas%filename.jpg&shared_with_me=true","message":"$absolutePath must be relative to \"files\"","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"27.1.3.1","exception":{"Exception":"InvalidArgumentException","Message":"$absolutePath must be relative to \"files\"","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":1944,"function":"getPathRelativeToFiles","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2052,"function":"lockPath","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/Node.php","line":382,"function":"lockFile","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/ShareAPIController.php","line":1770,"function":"lock","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/Controller/ShareAPIController.php","line":976,"function":"lock","class":"OCA\\Files_Sharing\\Controller\\ShareAPIController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"getShares","class":"OCA\\Files_Sharing\\Controller\\ShareAPIController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":183,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/ocs/v1.php","line":64,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/ocs/v2.php","line":23,"args":["/var/www/html/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/Files/View.php","Line":2126,"CustomMessage":"--"}}
{"reqId":"orOXIhQYrVIM5oEuhwbz","level":3,"time":"2023-10-27T10:44:02+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Typed property OCP\\BackgroundJob\\Job::$time must not be accessed before initialization","userAgent":"--","version":"27.1.3.1","exception":{"Exception":"Error","Message":"Typed property OCP\\BackgroundJob\\Job::$time must not be accessed before initialization","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":93,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/html/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","Line":102,"CustomMessage":"--"}}
{"reqId":"wcOSgdtWjAaUSVuAa7ZA","level":3,"time":"2023-10-27T10:45:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Typed property OCP\\BackgroundJob\\Job::$time must not be accessed before initialization","userAgent":"--","version":"27.1.3.1","exception":{"Exception":"Error","Message":"Typed property OCP\\BackgroundJob\\Job::$time must not be accessed before initialization","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":93,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/html/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/html/nextcloud/lib/public/BackgroundJob/TimedJob.php","Line":102,"CustomMessage":"--"}}
{"reqId":"djwNv29YavfvN4gddA98","level":3,"time":"2023-10-27T15:47:11+00:00","remoteAddr":"192.168.35.1","user":"Jeef","app":"onlyoffice","method":"GET","url":"/index.php/core/preview?fileId=303599&c=cdfaeddac6bfd219cfbcaa59b444aa72&x=250&y=250&forceIcon=0&a=1","message":"GetConvertedUri: from conf to jpeg","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"27.1.3.1","exception":{"Exception":"GuzzleHttp\\Exception\\ClientException","Message":"Client error: `POST https://nc.jeef.site/index.php/apps/documentserver_community/ConvertService.ashx` resulted in a `404 Not Found` response:\n<!DOCTYPE html>\n<html class=\"ng-csp\" data-placeholder-focus=\"false\" lang=\"en\" data-locale=\"en\" translate=\"no\" >\n\t<head\n (truncated...)\n","Code":404,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":69,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Http/Client/Client.php","line":301,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":372,"function":"post","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":177,"function":"Request","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/DocumentService.php","line":91,"function":"SendRequestToConvertService","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/apps/onlyoffice/lib/Preview.php","line":269,"function":"GetConvertedUri","class":"OCA\\Onlyoffice\\DocumentService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/ProviderV1Adapter.php","line":53,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/GeneratorHelper.php","line":64,"function":"getThumbnail","class":"OC\\Preview\\ProviderV1Adapter","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":361,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":337,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":149,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Preview/Generator.php","line":116,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/PreviewManager.php","line":192,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/html/nextcloud/core/Controller/PreviewController.php","line":144,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/html/nextcloud/core/Controller/PreviewController.php","line":113,"function":"fetchPreview","class":"OC\\Core\\Controller\\PreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"getPreviewByFileId","class":"OC\\Core\\Controller\\PreviewController","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":183,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1068,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"GetConvertedUri: from conf to jpeg","CustomMessage":"GetConvertedUri: from conf to jpeg"}}
