example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.2.3
Operating system and version (eg, Ubuntu 20.04): 22.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.52
PHP version (eg, 7.4): 8.1
- Upgrade Nextcloud
too long for post see pastebin
'instanceid' => '----------------------------',
'objectstore' =>
'class' => '\\OC\\Files\\ObjectStore\\S3',
'arguments' =>
'bucket' => '------------------------------',
'key' => '----------------------------------',
'secret' => '---------------------------------------',
'use_ssl' => true,
'hostname' => '--------------------------------',
'passwordsalt' => '----------------------------------',
'secret' => '------------------------------------',
0 => 'nextcloud.domainnamehere',
'datadirectory' => '/var/www/nextcloud.domainhere/data',
'version' => '25.0.10.1',
'overwrite.cli.url' => 'https://nextcloud.domainnamehere',
'dbname' => 'dbname',
'dbhost' => 'localhost',
'dbuser' => 'dbuser',
'dbpassword' => '--------------------------',
'default_phone_region' => 'US',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'it',
'mail_domain' => '--------------',
'mail_smtphost' => '---------------',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => '--------',
'mail_smtppassword' => '-----------',
'app_install_overwrite' =>
0 => 'files_mindmap',
1 => 'printer',
2 => 'drawio',
3 => 'impersonate',
'updater.secret' => '$2y$10$q.cQpENgtHwUT3FyQRRHx.QEqFIGR4266zh8n7nHh480im4p4Kzcm',
'theme' => '',
'loglevel' => 3,
Too long for post see pastebin
Too long for post see pastebin:
https://pastebin.com/fWP5YbR5
This started today when I was trying to get CRON jobs to work. I installed reddis to get that working. Then I thought I would try to update th later version of NC. During that process I discovered that my disk space was filled up. I had to delete some data to allow me to do that. Mostly I deleted older versions of NC in the /var/www/nextcloud/data/update directories.
Since the update was not able to finish, it changed the status in version.php to the new update, but it wasn’t really that version as the update couldn’t extract.
I’ve been running into problems trying to complete the update. I was trying to get it to update to the latest 25.X version when it stopped. Now its telling me that I’m on version 26 and its trying to update to 27. None of that is true and I know I don’t want to skip major update versions.
Now when I go the site, it just says :
Nextcloud will be updated to version 25.04.1
Start Update (button)
When I click that button it goes through the update process, says its done and then goes back to the same page again.
I can’t get anywhere
Please help
Jason
