Stuck in Maintenance mode after clicking on update now
    • latest
    • Linux 6.8.0-51-generic x86_64
    Web server and version (e.g, Apache 2.4.25):
    • replace me
    • replace me
    • 8.4.7Is this the first time you’ve seen this error? (Yes / No):
    • yes
    • during updating to latest version
    Installation method (e.g. AlO, NCP, Bare Metal/Archive, etc.)
    • updater
    • no
[All I did, was clicking “UPDATE NOW” like usual, after a few hours still stuck in Maintenance mode]
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
If you have terminal access, you can enable/disable maintenance mode:
In this case, you can also try to run through all the upgrade changes from command line (without time and memory restrictions that you’ll probably have on the web interface):
If you don’t have terminal access, you can try to edit the config.php file and change the variable for maintenance mode and hope this time in runs through. If not there is a problem somewhere, and the log files are the best pointer what might be wrong:
See Built-in Updater: Troubleshooting
THank you the last solution you gave, did the trick. thank you
