Stt_whisper2: add timestamp to transcript during transcribe audio
example
longer
example
here
Nextcloud version (eg, 29.0.5): 29.0.8
Operating system and version (eg, Ubuntu 24.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): nginx 1.24.0
PHP version (eg, 8.3): 8.2
Not showing timestamps in transcipt while transcribing a file through Nextcloud Assistant.
Is this the first time you’ve seen this error? (Y/N):N
Skipping remaining data requests for now.
  1. Select Nextcloud Assistant
  2. Choose Transcribe
  3. Select an audio file.
  4. Add to AI Queue.
  5. Results are raw text. No timestamps. No EOLs.
If the balance of the rest of the information below is necessary, let me know.
Thanks!
NO errors shown in logging.
PASTE HERE
PASTE HERE
PASTE HERE
Got a response that whisper2 has been updated for Nextcloud 30.
Not there yet, but it was interesting when it ran on 29.
I’ve been able to get timestamps at the chunking level which is helpful. The local changes required in the docker container as below. The changes are not persistent if the docker container is redownloaded.
Enter the container with:
docker exec -it <container_id> /bin/bash
apt update && apt install vim
to edit the main.py file.
In main.py, I changed the segments line to read:
segments, _ = model.transcribe(word_timestamps=True, audio=file_name)
and changed the respective line as modified below:
            for segment in segments:
                segmentTime = f"[{segment.start:.2f}s -> {segment.end:.2f}s]"
                transcript += f"{segmentTime} {segment.text}\n"
then, restart the container with:
docker restart <container_id>
