example
longer
example
here
Nextcloud version (eg, 18.0.2): 20.0.2
Operating system and version (eg, Ubuntu 20.04): Centos 7.8
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 7.1): 7.4
Strange garbage on screen after upgrading
- Upgrade to NC 20.0.2 via web interface
- Finish upgrade
- Go to site
Can't get into interface to check
'instanceid' => 'redacted',
'passwordsalt' => 'verysalty',
'secret' => '-------',
0 => '',
'datadirectory' => '/home/phil/cloud/data',
'version' => '20.0.2.2',
'overwrite.cli.url' => 'https://serveraddress/newcloud',
'dbname' => 'newcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'dbuser',
'dbpassword' => 'secretdbpassword',
==> ../../logs/access_log <==
xx.xxx.xxx.xx - - [27/Nov/2020:11:55:46 +0100] "GET /newcloud/ HTTP/1.1" 302 - "-" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:82.0) Gecko/20100101 Firefox/82.0"
xx.xxx.xxx.xxx - - [27/Nov/2020:11:55:47 +0100] "GET /newcloud/index.php/login HTTP/1.1" 200 4409 "-" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:82.0) Gecko/20100101 Firefox/82.0"
