Switching the primary storage to a S3 bucket is this just changing the config or do you need to make more post changes? right now I het erros that files cannot be found.
Check https://github.com/nextcloud/server/issues/5516 for the logs.
I’d assume - because I haven’t explicitly done it - you’d need to follow the standard procedure:
I’m guessing you’ve mounted S3 locally, though if not this is likely wrong advice ![]()
It was not locally mounted but I used this manual: https://docs.nextcloud.com/server/12/admin_manual/configuration_files/primary_storage.html#amazon-s3
But it is unclear how the next steps should be to make this work.
@MorrisJobke @nickvergessen @enoch85
Perhaps one of those can help. Disregard my previous comment
