"statusMessageTimestamp is not a valid attribute" After 24 -> 25 upgrade
    • 25.0.13.2
    • Truenas Core 13.1-RELEASE-p9 (latest release for truenas core)
    • not too sure about this one
    • Caddy v2.6.2
    • PHP 8.1.31
    • Yes
    • When attempting to upgrade from V24 to V25
    • I don’t remember the original install method for V24, but for V25, I downloaded the server.zip from nextcloud archives.
    • Yes, using Cloudflare
Before seeing the real issues below, I actually ran into a different one which I have solved. That issue was exactly the same as outlined here:
I did the file replacement, taking specifically this commit hash:
Login page loads fine. After inputting correct creds, page redirects to myurl/apps/dashboard/ and client has error:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Log available below.
Unfortunately from searching online, this is not a common issue.
I’ve messed around with this a bit, and I am fairly confident that this is due to the user_status app. It is some desync from the application code and the database definition.
From my occ status:
nextcloud# occ status
  - installed: true
  - version: 25.0.13.2
  - versionstring: 25.0.13
  - edition:
  - maintenance: false
  - needsDbUpgrade: false
  - productname: Nextcloud
  - extendedSupport: false
The db seems to be up to date, and here’s how the user status table looks:
MariaDB [nextcloud]> describe oc_user_status
| Field                    | Type                | Null | Key | Default | Extra          |
| id                       | bigint(20) unsigned | NO   | PRI | NULL    | auto_increment |
| user_id                  | varchar(255)        | NO   | UNI | NULL    |                |
| status                   | varchar(255)        | NO   |     | NULL    |                |
| status_timestamp         | int(10) unsigned    | NO   | MUL | NULL    |                |
| is_user_defined          | tinyint(1)          | YES  | MUL | NULL    |                |
| message_id               | varchar(255)        | YES  |     | NULL    |                |
| custom_icon              | varchar(255)        | YES  |     | NULL    |                |
| custom_message           | longtext            | YES  |     | NULL    |                |
| clear_at                 | int(10) unsigned    | YES  | MUL | NULL    |                |
| is_backup                | tinyint(1)          | YES  |     | 0       |                |
| status_message_timestamp | int(10) unsigned    | NO   | MUL | 0       |                |
11 rows in set (0.001 sec)
So to me, it seems like there’s an issue with how the table’s status_message_timestamp field is getting mapped via the mapper from /lib/public/AppFramework/Db/QBMapper.php
I don’t really want to dive in the code to mess with things, but I wonder if it’s due to the difference between status_message_timestamp and statusMessageTimestamp like the stack trace is suggesting?
I also just tried to disable the user_status app but it appears to not be possible. Is this like the theming app which cannot be disabled, or am I doing this wrong somehow?
nextcloud# occ app:disable user_status
  Not enough arguments (missing: "app-id").
app:disable <app-id>...
  1. Upgrade from V24 to V25 (latest)
  2. When running into the issue of passwordHash, replace file as suggested (server/lib/private/Authentication/Token/PublicKeyToken.php at adfe367106ccf1dd158099f10be021702297ebb5 · nextcloud/server · GitHub)
  3. Attempt to log into the app.
Here is a relevant excerpt of two instances of this happening by refreshing client:
    "reqId": "6XZ5ANUkf6Gf29wu1T8J",
    "level": 3,
    "time": "2025-04-27T22:19:49-07:00",
    "remoteAddr": "192.168.1.199",
    "user": "admin",
    "app": "no app in context",
    "method": "GET",
    "url": "/ocs/v2.php/apps/user_status/api/v1/user_status?format=json",
    "message": "statusMessageTimestamp is not a valid attribute",
    "userAgent": "Mozilla/5.0 (Windows) mirall/3.16.0 (build 20250306) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)",
    "version": "25.0.13.2",
    "exception": {
        "Exception": "BadFunctionCallException",
        "Message": "statusMessageTimestamp is not a valid attribute",
        "Code": 0,
        "Trace": [
                "file": "/usr/local/www/nextcloud/lib/public/AppFramework/Db/Entity.php",
                "line": 165,
                "function": "setter",
                "class": "OCP\\AppFramework\\Db\\Entity",
                "type": "->",
                "args": [
                    "statusMessageTimestamp",
                        1712050254
                "line": 73,
                "function": "__call",
                "type": "->",
                "args": [
                    "setStatusMessageTimestamp",
                        1712050254
                "file": "/usr/local/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php",
                "line": 322,
                "function": "fromRow",
                "type": "::",
                "args": [
                        1,
                        "admin",
                        "offline",
                        1745783105,
                        0,
                        "And 6 more entries, set log level to debug to see all entries"
                "line": 362,
                "function": "mapRowToEntity",
                "class": "OCP\\AppFramework\\Db\\QBMapper",
                "type": "->",
                "args": [
                        1,
                        "admin",
                        "offline",
                        1745783105,
                        0,
                "file": "/usr/local/www/nextcloud/apps/user_status/lib/Db/UserStatusMapper.php",
                "line": 111,
                "function": "findEntity",
                "type": "->",
                "args": [
                        "OC\\DB\\QueryBuilder\\QueryBuilder"
                "file": "/usr/local/www/nextcloud/apps/user_status/lib/Service/StatusService.php",
                "line": 153,
                "function": "findByUserId",
                "class": "OCA\\UserStatus\\Db\\UserStatusMapper",
                "type": "->",
                "args": [
                    "admin"
                "file": "/usr/local/www/nextcloud/apps/user_status/lib/Controller/UserStatusController.php",
                "line": 84,
                "class": "OCA\\UserStatus\\Service\\StatusService",
                "type": "->",
                "args": [
                    "admin"
                "file": "/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",
                "line": 225,
                "function": "getStatus",
                "class": "OCA\\UserStatus\\Controller\\UserStatusController",
                "type": "->",
                "args": []
                "line": 133,
                "function": "executeController",
                "class": "OC\\AppFramework\\Http\\Dispatcher",
                "type": "->",
                "args": [
                    "getStatus"
                "file": "/usr/local/www/nextcloud/lib/private/AppFramework/App.php",
                "line": 172,
                "function": "dispatch",
                "type": "->",
                "args": [
                    "getStatus"
                "file": "/usr/local/www/nextcloud/lib/private/Route/Router.php",
                "line": 298,
                "function": "main",
                "class": "OC\\AppFramework\\App",
                "type": "::",
                "args": [
                    "getStatus",
                        "OC\\AppFramework\\DependencyInjection\\DIContainer"
                        "ocs.user_status.UserStatus.getStatus"
                "file": "/usr/local/www/nextcloud/ocs/v1.php",
                "line": 64,
                "function": "match",
                "class": "OC\\Route\\Router",
                "type": "->",
                "args": [
                    "/ocsapp/apps/user_status/api/v1/user_status"
                "file": "/usr/local/www/nextcloud/ocs/v2.php",
                "line": 23,
                "args": [
                "function": "require_once"
        "File": "/usr/local/www/nextcloud/lib/public/AppFramework/Db/Entity.php",
        "Line": 136,
        "CustomMessage": "--"
    "reqId": "P6ns78VGZKjA3BHuSLkB",
    "level": 3,
    "user": "admin",
    "method": "GET",
    "url": "/ocs/v2.php/apps/notifications/api/v2/notifications?format=json",
    "exception": {
        "Code": 0,
        "Trace": [
                "line": 165,
                "type": "->",
                "args": [
                        1712050254
                "line": 73,
                "type": "->",
                "args": [
                        1712050254
                "line": 322,
                "type": "::",
                "args": [
                        1,
                        "admin",
                        "offline",
                        1745783105,
                        0,
                "line": 340,
                "type": "->",
                "args": [
                        1,
                        "admin",
                        "offline",
                        1745783105,
                        0,
                "line": 125,
                "function": "findEntities",
                "type": "->",
                "args": [
                "line": 163,
                "function": "findByUserIds",
                "type": "->",
                "args": [
                        "admin"
                "file": "/usr/local/www/nextcloud/apps/user_status/lib/Connector/UserStatusProvider.php",
                "line": 50,
                "type": "->",
                "args": [
                        "admin"
                "file": "/usr/local/www/nextcloud/lib/private/UserStatus/Manager.php",
                "line": 69,
                "function": "getUserStatuses",
                "class": "OCA\\UserStatus\\Connector\\UserStatusProvider",
                "type": "->",
                "args": [
                        "admin"
                "file": "/usr/local/www/nextcloud/apps/notifications/lib/Controller/EndpointController.php",
                "line": 84,
                "class": "OC\\UserStatus\\Manager",
                "type": "->",
                "args": [
                        "admin"
                "line": 225,
                "function": "listNotifications",
                "class": "OCA\\Notifications\\Controller\\EndpointController",
                "type": "->",
                "args": [
                    "v2"
                "line": 133,
                "type": "->",
                "args": [
                    "listNotifications"
                "line": 172,
                "type": "->",
                "args": [
                    "listNotifications"
                "line": 298,
                "function": "main",
                "type": "::",
                "args": [
                        "v2",
                        "ocs.notifications.Endpoint.listNotifications"
                "line": 64,
                "type": "->",
                "args": [
                    "/ocsapp/apps/notifications/api/v2/notifications"
                "line": 23,
                "args": [
        "Line": 136,
Don’t think this is relevant here, but I will paste relevant logs if community thinks so.
nextcloud# occ config:list system
            "localhost",
            "redacted",
            "192.168.1.70",
            "191.168.1.199"
        "dbtype": "mysql",
        "overwrite.cli.url": "https:\/\/redacted\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "logtimezone": "America\/Vancouver",
        "default_phone_region": "US",
        "log_type": "file",
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "loglevel": "2",
        "logrotate_size": "104847600",
        "redis": {
            "port": 0
        "overwritehost": "redacted",
        "overwriteprotocol": "https",
        "htaccess.RewriteBase": "\/",
        "theme": "",
        "preview_max_memory": 4096,
        "preview_max_filesize_image": 256,
        "enabledPreviewProviders": [
            "OC\\Preview\\Image",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\TIFF",
            "OC\\Preview\\Movie",
            "OC\\Preview\\MKV",
            "OC\\Preview\\MP4",
            "OC\\Preview\\AVI"
        "memories.ffmpeg_path": "\/usr\/local\/bin\/ffmpeg",
        "memories.ffprobe_path": "\/usr\/local\/bin\/ffprobe",
        "memories.transcoder": "\/usr\/local\/www\/nextcloud\/apps\/memories\/exiftool-bin\/go-vod-amd64",
        "memories.no_transcode": false,
        "memories.qsv": false,
        "memories.gis_type": 1
    "apps": {
        "activity": {
            "enabled": "yes",
            "installed_version": "2.17.0",
            "types": "filesystem"
        "admin_audit": {
            "enabled": "yes",
            "installed_version": "1.15.0",
            "types": "logging"
        "announcementcenter": {
            "enabled": "no",
            "installed_version": "6.3.1",
            "types": "logging"
        "appointments": {
            "enabled": "no",
            "hk": "9c525f426914abccf605e1cd34f4e31a232e872baa4eaf83ec475c6d9c35a9ae",
            "installed_version": "1.14.14",
            "tiv": "0fc3ad6af30fce00c81ad1c76fe3e734",
            "types": "dav"
        "apporder": {
            "enabled": "no",
            "installed_version": "0.15.0",
            "types": ""
        "backgroundjob": {
            "lastjob": "706975"
        "bbb": {
            "enabled": "no",
            "installed_version": "2.4.0",
            "types": "prevent_group_restriction"
        "breezedark": {
            "enabled": "no",
            "installed_version": "24.0.3",
            "types": ""
        "bruteforcesettings": {
            "enabled": "yes",
            "installed_version": "2.5.0",
            "types": ""
        "calendar": {
            "enabled": "yes",
            "installed_version": "4.6.8",
            "types": ""
        "camerarawpreviews": {
            "enabled": "no",
            "installed_version": "0.8.1",
        "circles": {
            "enabled": "no",
            "installed_version": "24.0.1",
            "loopback_tmp_path": "\/",
            "loopback_tmp_scheme": "https",
            "maintenance_run": "0",
            "maintenance_update": "{\"maximum\":3,\"4\":1669773602,\"3\":1686503103,\"2\":1686504905,\"1\":1686504905,\"5\":1669431601}",
            "migration_22": "1",
            "migration_run": "0",
            "types": "filesystem,dav"
        "cloud_federation_api": {
            "enabled": "yes",
            "installed_version": "1.8.0",
        "comments": {
            "enabled": "yes",
            "types": "logging"
        "contacts": {
            "enabled": "yes",
            "installed_version": "5.5.3",
            "types": "dav"
        "contactsinteraction": {
            "enabled": "yes",
            "installed_version": "1.6.0",
            "types": "dav"
        "core": {
            "backgroundjobs_mode": "cron",
            "default_encryption_module": "OC_DEFAULT_MODULE",
            "files_metadata": "{\"photos-original_date_time\":{\"value\":null,\"type\":\"int\",\"indexed\":true,\"editPermission\":0},\"photos-exif\":{\"value\":null,\"type\":\"array\",\"indexed\":false,\"editPermission\":0},\"photos-ifd0\":{\"value\":null,\"type\":\"array\",\"indexed\":false,\"editPermission\":0},\"photos-size\":{\"value\":null,\"type\":\"array\",\"indexed\":false,\"editPermission\":0},\"photos-gps\":{\"value\":null,\"type\":\"array\",\"indexed\":false,\"editPermission\":0},\"photos-place\":{\"value\":null,\"type\":\"string\",\"indexed\":true,\"editPermission\":0},\"files-live-photo\":{\"value\":null,\"type\":\"string\",\"indexed\":false,\"editPermission\":1}}",
            "files_metadata_installed": "1",
            "installedat": "1668315693.697",
            "lastcron": "1745817600",
            "lastupdateResult": "{\"version\":\"24.0.12.1\",\"versionstring\":\"Nextcloud 24.0.12\",\"url\":\"https:\\\/\\\/download.nextcloud.com\\\/server\\\/releases\\\/nextcloud-24.0.12.zip\",\"web\":\"https:\\\/\\\/docs.nextcloud.com\\\/server\\\/24\\\/admin_manual\\\/maintenance\\\/upgrade.html\",\"changes\":\"https:\\\/\\\/updates.nextcloud.com\\\/changelog_server\\\/?version=24.0.12\",\"autoupdater\":\"1\",\"eol\":\"1\"}",
            "lastupdatedat": "0",
            "moveavatarsdone": "yes",
            "oc.integritycheck.checker": "{\"theming_old_broken\":{\"EXTRA_FILE\":{\"js\\\/3rdparty\\\/jscolor\\\/LICENSE.txt\":{\"expected\":\"\",\"current\":\"7633623b66b5e686bb94dd96a7cdb5a7e5ee00e87004fab416a5610d59c62badaf512a2e26e34e2455b7ed6b76690d2cd47464836d7d85d78b51d50f7e933d5c\"},\"js\\\/3rdparty\\\/jscolor\\\/jscolor.min.js\":{\"expected\":\"\",\"current\":\"571928b11f53b1784139f2b266d2918cf8fa0256586c7d0f37f8a1fc5c16cbf3d14987e6c24ecf3ae82b1d37d985ed16b3fb4bbbf0450b4bfbcf5f2bc86b35e7\"},\"js\\\/3rdparty\\\/jscolor\\\/jscolor.js\":{\"expected\":\"\",\"current\":\"a1ff09cd6364301a1560661ebaa34839a641d287af6c298c8284620324aea5ba3b1fa7ab3f835c81d12fd60a2e99d74daa9e1948f2ccc3b4c54b183b2162488d\"},\"js\\\/settings-admin.js\":{\"expected\":\"\",\"current\":\"5505fefa979461a0b374e847424cc2240aced890b5fb2e2a8656a50a9d5885b0dc0498a1434693774c1e5a35b197e31d70ea0cacdab4c3dc1167eddd6577ee6d\"},\"css\\\/settings-admin.scss\":{\"expected\":\"\",\"current\":\"eca940dd2505dfa168daa957db4250ca3637f433a7ede41705c92fede7d76d5be14eadb49525e3d655de908d31b8bb2daf69e389fa3fbef522c8734e8cb9c242\"},\"css\\\/settings-admin.css\":{\"expected\":\"\",\"current\":\"6361b404ed7c81d50006a2cad9f996caca207d1b96e449e13f44d147b7c1a61bcee5deea64c0003e014679c3f32a40f89f47e44fb15b926131fb311f682d710d\"},\"css\\\/settings-admin.css.map\":{\"expected\":\"\",\"current\":\"9c71db6396f51db497565da126fa1372fc9da6b661f596b61b536494a7ae675a28a33052bcf2ff5e24f57351eb88535cb9f432391ad2c029b33624193e21eeb5\"},\"lib\\\/Migration\\\/MigrateUserConfig.php\":{\"expected\":\"\",\"current\":\"1f188a3f0ce9eff7a4bb583b7b42f08a064e876448259154fa6aad969d4ea625c043b91e2bb5d47cf04f7ae4250a6256f6f52f33ac55024404a165d7ad7c8c13\"},\"lib\\\/Migration\\\/MigrateAdminConfig.php\":{\"expected\":\"\",\"current\":\"d943d1dc01f2508e4a042c8753b9934913452c9bf3e2aad4fa4397e35a26b4443031f2797e90082ea1ec5424049f3d2a63cfb3fff69162a7b2f2d2380f251084\"}}}}",
            "previewsCleanedUp": "1",
            "public_files": "files_sharing\/public.php",
            "public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
            "theming.variables": "a123f4e02b6daa90672ad154e99d6802",
            "updater.secret.created": "1669830714",
            "vendor": "nextcloud"
        "dashboard": {
            "enabled": "yes",
            "installed_version": "7.5.0",
            "types": ""
        "dav": {
            "buildCalendarReminderIndex": "yes",
            "buildCalendarSearchIndex": "yes",
            "builtSocialSearchIndex": "yes",
            "chunks_migrated": "1",
            "enabled": "yes",
            "installed_version": "1.24.0",
            "needs_system_address_book_sync": "no",
            "regeneratedBirthdayCalendarsForYearFix": "yes",
        "deck": {
            "enabled": "yes",
            "installed_version": "1.8.8",
            "types": "dav"
        "drawio": {
            "DrawioAutosave": "yes",
            "DrawioLang": "auto",
            "DrawioLibraries": "no",
            "DrawioOffline": "no",
            "DrawioTheme": "kennedy",
            "DrawioUrl": "https:\/\/embed.diagrams.net",
            "enabled": "no",
            "installed_version": "2.1.4",
        "encryption": {
            "enabled": "no",
            "installed_version": "2.12.0",
            "masterKeyId": "master_90fb0e85",
            "publicShareKeyId": "pubShare_90fb0e85",
            "recoveryKeyId": "recoveryKey_90fb0e85",
        "extract": {
            "enabled": "no",
            "installed_version": "1.3.6",
            "types": ""
        "federatedfilesharing": {
            "enabled": "yes",
            "types": ""
        "federation": {
            "enabled": "no",
            "installed_version": "1.14.0",
            "types": "authentication"
        "files": {
            "enabled": "yes",
            "installed_version": "1.20.1",
        "files_accesscontrol": {
            "enabled": "no",
            "installed_version": "1.14.1",
        "files_archive": {
            "enabled": "no",
            "installed_version": "1.1.2",
        "files_fulltextsearch": {
            "enabled": "no",
        "files_markdown": {
            "enabled": "no",
            "types": ""
        "files_pdfviewer": {
            "enabled": "yes",
            "installed_version": "2.6.0",
            "types": ""
        "files_reminders": {
            "enabled": "no",
            "installed_version": "1.1.0",
            "types": "dav"
        "files_rightclick": {
            "enabled": "no",
            "types": ""
        "files_sharing": {
            "enabled": "yes",
            "installed_version": "1.17.0",
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.18.0",
        "firstrunwizard": {
            "enabled": "no",
            "installed_version": "2.13.0",
            "types": "logging"
        "forms": {
            "enabled": "no",
            "installed_version": "2.5.2",
            "types": ""
        "fulltextsearch": {
            "enabled": "no",
            "installed_version": "24.0.0",
            "types": ""
        "integration_github": {
            "enabled": "no",
            "installed_version": "1.0.4",
            "types": ""
        "integration_reddit": {
            "enabled": "no",
            "installed_version": "1.0.7",
            "types": ""
        "logreader": {
            "enabled": "yes",
            "installed_version": "2.10.0",
            "types": ""
        "lookup_server_connector": {
            "enabled": "yes",
            "installed_version": "1.13.0",
        "maps": {
            "enabled": "yes",
            "osrmDEMO": "1",
        "memories": {
            "enabled": "no",
            "installed_version": "7.4.1",
            "last_index_job_duration": "86.35",
            "last_index_job_start": "1742408102",
            "last_index_job_status": "Indexing completed successfully",
            "last_index_job_status_type": "success",
            "types": ""
        "nextcloud_announcements": {
            "enabled": "no",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
            "types": "logging"
        "notes": {
            "enabled": "no",
            "installed_version": "4.5.1",
            "types": ""
        "notifications": {
            "enabled": "yes",
            "installed_version": "2.13.1",
            "types": "logging"
        "oauth2": {
            "enabled": "yes",
            "installed_version": "1.13.1",
        "onlyoffice": {
            "enabled": "no",
            "installed_version": "9.0.0",
        "password_policy": {
            "enabled": "yes",
        "photos": {
            "enabled": "yes",
            "installed_version": "2.0.1",
            "lastPlaceMappedUser": "wl",
            "lastPlaceMappingDone": "true",
            "types": "dav,authentication"
        "previewgenerator": {
            "enabled": "no",
            "heightSizes": "512",
            "installed_version": "5.6.0",
            "squareSizes": "512",
            "types": "filesystem",
            "widthSizes": "512"
        "privacy": {
            "enabled": "yes",
            "fullDiskEncryptionEnabled": "0",
            "installed_version": "1.9.0",
            "readableLocation": "ca",
            "types": ""
        "provisioning_api": {
            "enabled": "yes",
        "recommendations": {
            "enabled": "yes",
            "installed_version": "1.4.0",
            "types": ""
        "related_resources": {
            "enabled": "yes",
            "types": ""
        "richdocuments": {
            "enabled": "no",
            "installed_version": "6.3.9",
        "serverinfo": {
            "cached_count_filecache": "849660",
            "cached_count_storages": "9",
            "enabled": "yes",
            "types": ""
        "settings": {
            "enabled": "yes",
            "installed_version": "1.7.0",
            "types": ""
        "sharebymail": {
            "enabled": "no",
        "socialsharing_twitter": {
            "enabled": "no",
            "installed_version": "3.1.0",
            "types": ""
        "spreed": {
            "enabled": "no",
            "has_reference_id": "yes",
            "installed_version": "18.0.5",
            "project_access_invalidated": "1",
            "signaling_token_privkey_es256": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_pubkey_es256": "***REMOVED SENSITIVE VALUE***",
            "types": "dav,prevent_group_restriction"
        "support": {
            "SwitchUpdaterServerHasRun": "yes",
            "enabled": "yes",
            "types": "session"
        "survey_client": {
            "enabled": "yes",
            "types": ""
        "systemtags": {
            "enabled": "no",
            "types": "logging"
        "text": {
            "enabled": "yes",
            "installed_version": "3.6.0",
            "types": "dav"
        "theming": {
            "backgroundMime": "image\/jpeg",
            "cachebuster": "4",
            "color": "#E23B9A",
            "enabled": "yes",
            "slogan": "***REMOVED SENSITIVE VALUE***",
            "types": "logging"
        "twofactor_backupcodes": {
            "enabled": "yes",
            "types": ""
        "unsplash": {
            "enabled": "no",
            "types": ""
        "updatenotification": {
            "appointments": "1.14.14",
            "breezedark": "24.0.3",
            "calendar": "3.5.7",
            "camerarawpreviews": "0.8.1",
            "contacts": "4.2.5",
            "core": "24.0.12.1",
            "deck": "1.7.4",
            "drawio": "2.1.1",
            "enabled": "no",
            "files_archive": "1.1.2",
            "files_markdown": "2.4.0",
            "forms": "2.5.2",
            "integration_reddit": "1.0.7",
            "maps": "0.2.2",
            "onlyoffice": "7.7.0",
            "previewgenerator": "5.2.4",
            "richdocuments": "6.3.5",
            "spreed": "14.0.11",
            "types": "",
            "update_check_errors": "0"
        "user_status": {
            "enabled": "yes",
            "installed_version": "1.5.0",
            "types": ""
        "viewer": {
            "enabled": "yes",
            "types": ""
        "weather_status": {
            "enabled": "yes",
            "types": ""
        "workflow_media_converter": {
            "enabled": "no",
            "types": ""
        "workflowengine": {
            "enabled": "yes",
            "installed_version": "2.7.0",
nextcloud# occ app:list
  - activity: 2.17.0
  - admin_audit: 1.15.0
  - bruteforcesettings: 2.5.0
  - calendar: 4.6.8
  - cloud_federation_api: 1.8.0
  - comments: 1.15.0
  - contacts: 5.5.3
  - contactsinteraction: 1.6.0
  - dashboard: 7.5.0
  - dav: 1.24.0
  - deck: 1.8.8
  - federatedfilesharing: 1.15.0
  - files: 1.20.1
  - files_pdfviewer: 2.6.0
  - files_sharing: 1.17.0
  - files_trashbin: 1.15.0
  - files_versions: 1.18.0
  - logreader: 2.10.0
  - lookup_server_connector: 1.13.0
  - maps: 1.1.0
  - notifications: 2.13.1
  - oauth2: 1.13.1
  - password_policy: 1.15.0
  - photos: 2.0.1
  - privacy: 1.9.0
  - provisioning_api: 1.15.0
  - recommendations: 1.4.0
  - related_resources: 1.0.4
  - serverinfo: 1.15.0
  - settings: 1.7.0
  - support: 1.8.0
  - survey_client: 1.13.0
  - text: 3.6.0
  - theming: 2.0.1
  - twofactor_backupcodes: 1.14.0
  - user_status: 1.5.0
  - viewer: 1.9.0
  - weather_status: 1.5.0
  - workflowengine: 2.7.0
  - circles: 24.0.1
  - encryption: 2.12.0
  - federation: 1.14.0
  - files_external
  - files_rightclick: 1.6.0
  - firstrunwizard: 2.13.0
  - nextcloud_announcements: 1.13.0
  - sharebymail: 1.14.0
  - suspicious_login
  - systemtags: 1.14.0
  - theming_old_broken
  - twofactor_totp
  - updatenotification: 1.14.0
  - user_ldap
Unfortunately I cannot help you with this specific error, especially because the version you’ve upgraded to is already end of life since 1,5 years. Depending on the number of users using the server, it might be faster to export your data and do an install from scratch with Nexcloud 31.
For the record, I never ended up fixing the underlying issue, but I was able to disable the app manually (through a non-aliased occ command) which seemed to work for now.
