Prelude:
Nextcloud AIO v7.6.2 installed on windows 10 following https://nextcloud.com/it/blog/la-tua-guida-a-nextcloud-all-in-one-su-windows-10-e-11/
This is the second installation on the same machine make on September 2023
It works, but unlike the previous installation I haven’t found a way to start docker engine automatically when the machine boots.
Previously I used windows task scheduler to launch “C:\Program Files\Docker\Docker\Docker Desktop.exe”
Now it’s no longer possible. Some processors labeled docker start but not the docker engine.
Main Question:
What other system do users of aio windows use to automatically start it at startup without logging in?
Thanks in advance for the suggestions.
