I succeeded in building an onlyoffice server and applying the ssl certificate.
I checked the ‘welcome’ page by connecting to HTTPS and checked the healthcheck for ‘true’.
Perhaps the deployment itself doesn’t seem to be a problem.
But the problem occurred in the process of connecting to my cloud.
Error Msg:
Error when trying to connect (cURL error 60: SSL certificate problem: unable to get local issuer certificate (see libcurl - Error Codes) for https://my_onlyoffice_page/healthcheck)
When I accessed the web page, I saw that the certificate chain was applied normally (letscrypt), default.json and local.Checked json.
I checked my port settings and secret key creation normally, and I also checked the token’s enable value (true) change.
But my problem still exists.
Please help me
With Best Regard,
Thank you
