I am facing a SSL handshake issue from an android 4.4.2 device.
i have a setup where I sync my contancts on Nextcloud with multiple Android devices using Davx5 (davdroid). It used to work fine but now one of my devices stopped syncing. Don’t know for sure but I have a sense that this could be related to the snap update which affected a specific Android version because my other android device (and thunderbird as well) is continuing to sync properly.
The error I am getting from Davx5 says:
2019-04-16 10:35:50 2 [HttpClient] ← HTTP FAILED: javax.net.ssl.SSLHandshakeException: javax.net.ssl.SSLProtocolException: SSL handshake aborted: ssl=0x5e210c78: Failure in SSL library, usually a protocol error
error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure (external/openssl/ssl/s23_clnt.c:744 0x5e2b2830:0x00000000)
Full Error Log: --- BEGIN DEBUG INFO ---LOGS:2019-04-16 10:35:50 2 [ui.setup.DavResourceFi - Pastebin.com
From what I read on Davx5 forums, this could be about incompatible ciphers (https://forums.bitfire.at/topic/1091/handshake-error-sl23_get_server_hello/15). But I am not sure what they are, how to test or change them in a nextcloud snap installation setting.
Any idea how to proceed with troubleshooting?
