Useful tricks for getting the most out of your SSH session.
Consider generating a new SSH key pair called ncp with
$ ssh-keygen -b 4096
Create a config so you can effortlessly SSH into your machine.
Add this to your ~/.ssh/config file:
Host ncp
User REPLACEMEWITHYOURUSERNAME
Hostname IP.ADD.RES.S
PreferredAuthentications publickey
IdentityFile ~/.ssh/ncp
If your SSH pub key (~/.ssh/ncp.pub) has been added to IPADDRESS:~/.ssh/authorized_keys, you should now be able to shell in by typing
$ ssh ncp
…and thanks to the ~/.ssh/config entry, the name of the server you’re trying to SSH into – namely ncp in this case – should autocomplete!
About the Author
This article was worked on by @just. Thank you so much for all you do! You may write your own articles by joining our wiki and documentation team on the forum.
