Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
I am using NextcloudPi vanilla 1.53.0 and I encountered strange problems with SSH.
I found it takes so long to SSH my RaspberryPi now, I tried with -vv and here is what I got (I replaced my real IP with 11.11.11.11) :
charles@11.11.11.11's password:
debug2: we sent a password packet, wait for reply
debug1: Authentication succeeded (password).
Authenticated to 11.11.11.11 ([11.11.11.11]:22).
debug1: channel 0: new [client-session]
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: network
### And here it stucks for 1 to 2 minutes ###
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug2: channel_input_open_confirmation: channel 0: callback start
debug2: fd 3 setting TCP_NODELAY
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug1: Sending environment.
debug1: Sending env LANG = en_GB.UTF-8
debug2: channel 0: request env confirm 0
debug2: channel 0: request shell confirm 1
debug2: channel_input_open_confirmation: channel 0: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 2097152
debug2: shell request accepted on channel 0
### Shell appears ###
Is this the first time you’ve seen this error? (Y/N): No.
As a matter of fact, I tried to burn a new NextcloudPi 1.53.0 on my SD card and the problem persists.
- Download the NCP 1.53.0 zip package from Releases · nextcloud/nextcloudpi · GitHub .
- Burn it to an empty SD card using RaspberryPi Imager, and in its “custom settings” set your account name & passwd and check the Enable SSH box.
- Insert the card to RaspberryPi and power it on, try to connect it via SSH.
I tried journalctl -r and the result makes me confused: it shows nothing suspicious.
This is the record of what happened when I tried to self-SSH the Rasp-Pi using established SSH from my PC.
Jan 20 20:47:50 raspberry-pi sshd[2960]: Starting session: shell on pts/2 for charles from 11.11.11.11 port 34030 id 0
Jan 20 20:47:50 raspberry-pi sshd[2911]: User child is on pid 2960
Jan 20 20:45:40 raspberry-pi systemd-logind[445]: New session 11 of user charles.
Jan 20 20:45:40 raspberry-pi systemd[1]: Started Session 11 of user charles.
Jan 20 20:45:40 raspberry-pi sshd[2911]: pam_unix(sshd:session): session opened for user charles(uid=1000) by (uid=0)
Jan 20 20:45:40 raspberry-pi sshd[2911]: Accepted password for charles from 11.11.11.11 port 34030 ssh2
Jan 20 20:45:33 raspberry-pi sshd[2911]: Connection from 11.11.11.11 port 34030 on 11.11.11.11 port 22 rdomain ""
As you can see there is a 1 minute delay.
For this happens on a system with Nextcloud NOT activated, I did not check NC logs. I did not modify any part of the system after powered on, either.
I would really appreciate it if anyone could look into this and give me a hint on what I should do next.
P.S.: This is my first time on this forum and I am not a native English speaker. Please let me know if there’s anything confusing about my expressions or any further information is needed.
