Nextcloud version: 11.0.2.7
Operating system and version: Ubuntu 16.04.2
Apache or nginx version: Apache/2.4.18
Trying to address an error I’ve had for several days. Client upload failing on certain files, which seem “stuck” - unable to delete through client or web interface. Tried this to no avail: https://help.nextcloud.com/t/file-is-locked-how-to-unlock/1883/9
Ran sudo -u www-data php occ files:scan —all and got the following output: https://pastebin.com/YfERsfpM
Ran it again and got this: pastebin.com/sXQyt8qp (apologies, it won’t let me add more than 2 links)
Have already tried unlocking files as described in the post linked above, the command seemed to execute but had no apparent effect. I’m stuck, please help!
OC\Encryption\Exceptions\DecryptionFailedException: Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you. Repeated many times
'instanceid' => '************',
'passwordsalt' => '************',
'secret' => '************ array (
0 => '************',
1 => '************',
'datadirectory' => '/mnt/volume-fra1-01-part1/nextcloud/data',
'overwrite.cli.url' => 'https://************/nextcloud',
'version' => '11.0.2.7',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '************',
'logtimezone' => 'UTC',
