Hi everyone
I ran into something weird today and wanted to check if anyone else using the Android client has seen this.
I’m currently on Android 14 (Pixel 7), and after downloading Spotify Premium APK v9.0.74.823, the app installs fine but just refuses to open. No crash report, no logs in the logcat, and nothing in the Nextcloud sync folder either. It’s as if the app gets blocked silently. I’ve double-checked my settings: install from unknown sources is enabled, battery optimization is off, and I even reinstalled it from scratch.
I’ve seen some people mention it could be related to scoped storage changes in Android 14 or some new Play Protect silent enforcement. I don’t think this is a Nextcloud bug per se, but I do use Nextcloud as my personal APK sync tool between devices, so I’m wondering:
Could Nextcloud’s Android file handling permissions or sandboxing interfere with sideloaded APKs behaving oddly?
Would love if someone who’s handled similar issues (maybe with F-Droid or custom builds) could shed some light. ![]()
Thanks in advance! If I find a workaround or stable mirror for this version, I’ll drop it here later for those interested.
Update: I found a clean and stable source that worked perfectly on both Android 13 and 14 (tested). For anyone needing it:
