Spell checker is not working though enabled in Advanced Settings. I found that even the folder SpellChecker is missing in documentserver/… Is it disabled functionality for the community version?
UPD: Spellchecker works correctly when using external desktop client connected with NC.
How this should help?.. I installed npm, though it doesn’t help with language proof-reading… I even will be glad if standard Chrome proof-reading in text frames may work, but it doesn’t.
Is there any update from Nextcloud devs or whomever support document server for Nextcloud? I would hope that spellcheck is a critical function of being able to use a document editor in Nextcloud. Is there a plan or roadmap to implement (fix) spellcheck on Nextcloud Onlyoffice?
Thank you for this reply! I’m not understanding your instructions on how to add spell check to the onlyoffice documentserver App in Nextcloud? I’m also not seeing the same location of files that you are? I’ve installed document server on my Nextcloud and my location of document server would be in my apps folder of Nextcloud:
nextcloud/apps/documentserver_community/
I’ve searched and I can see “SpellChekcer” referenced in Help and Images folders only.
Also, is it that you are removing (renaming) the node_modules and after updating the document server app will download a new version of node_modules? Is this what adds Spell check to the App documentserver?
I have a nice news. With the last update of the community version of OnlyOffice I found that spellchecker is working, plus it is possible to select other languages!
