Hi
I 'am not sure to understand all.
I have started with nextcloud for only few month, and I find it great.
But now I have huge data on my nextcloud (60GB).
I would like to move some folders on my nextcloud outside to another folders on my synology nas.
And I would also like to import data from other location on my NAS to nextcloud folders.
My idea is to put this data on USB key and bring it at my work place copy on my local nextcloud and restart nextcloud.
The aim is to speed up the synchronisation .
My undestanding is that it is possible by the following action.
- put nextcloud in maitenance mode
- copy file in nextcloud.
- scan (could you precise me the command)
- switch off maintenance mode .
it s that correct. Could you confirm and/or correct me
Thanks for your help
