Sort right click menu / context menu
I would like to sort the right click menu to put the “edit locally” to the top smh to make it easy to use it. and it would be also cool to make it “edit locally” to one click option for some files.
I don’t know if you can do that with theming or a dedicated app. You could just change the code directly but you would have to redo these changes after each update.
There are apps working with the menu, perhaps you’ll find some inspiration there:
