Hi, I am running Nextcloud 11 with PHP 7 in a Freenas Jail which works without any trouble.
Now I noticed that I can use WebDAV with a normal user account but if I use my admin account the error unauthorized is returned. Is this how it should be and can I enable it for the admin?
Thank you!
Thanks for the hint. I didn’t activate an app passcode but 2 factor authentication. Don’t remember anyone if it was before or after trying WebDAV. I’ll check this and report back.
Works like a charm after generating an app specific password. How can I forget this…
Thank you!
Yeah, I had the same thing. The two factor app really should warn people when it’s activated that they’ll need new tokens for any apps that sync with Nextcloud.
