SOLVED - Virtual File Problem on MAC
I have “MacBook Air M2 2022” and using “OS is Sequoia 15.0.1”.
I downloaded and setuped “macOS Virtual files 12+ (64 bit, universal)” via this link: Download and install Nextcloud (file name is “Nextcloud-3.14.2-macOS-vfs.pkg”)
But, This software downloaded ALL files/documents from NextCloud to my MAC. I can not be active VIRTUAL FILES option like Windows version.
I saw same problem one the same forums, but i never see solition.
At the same time, I tryed to “WebDAV” way. This way is ok, but too much slow in the MACos. For example; If I want to open one file, generally I have to wait around 1,5 maybe 2 minutes. But when I use windows os, I can open this file max in the 1 second.
Can you help me?
SOLUTION:
Settings →
a) Standard File Sync = NOT SELECT / CHOOSE ANYTHING
b) Second Tab is “Virtual File Sync”
b.1) General Settings → Enable Virtual Files must be ACTIVE
b.2) Enable Fast Sync must be ACTIVE
Just this…
Because this is a really large file? And the webdav way, you tried to hook up Nextcloud directly with apple+k?
Anything in the logs?
I found this report, but they use external storage (which might be different when using local server storage).
