example
longer
example
here
Nextcloud version (eg, 14.0.4):
Operating system and version (eg, Ubuntu 16.04):
PHP version (eg, 7.3):
I’m using an object storage as a primary storage (with OVH). It works ok, but when I open a folder with too many pictures, it crashed everything. My object storage becomes unavailable, and the only thing nextcloud would show is ‘storage not available’.
I’ve contacted OVH about that, and they’ve told me it’ because we use too many tokens, and I can only use 60 per minute. So they were saying that Nexctloud instead of using 1 big token for requests uses too many. Is that the case? I think the problem comes from them, but I prefer ask here first.
Thx!
Is this the first time you’ve seen this error? (Y/N):N
I get too many requests in the log.
PASTE HERE
PASTE HERE
