today i want to look inside my cloud and i saw an emty webpage. Iâm not sure everything works fine.
I mad my installation before 1/2 year and let it run automaticly. meanwhile i saw many error when i log in with putty.Can somebody help me to analize what happen ? I am not shur what version is on my cloud. i know its a 12 version.
I scaring to install it new, because of loosing my data.
Ciao
Nextcloud Pi 0.34.5
Nextcloud version (eg, 10.0.2): 12.0.3.3
Operating system and version (eg, Ubuntu 16.04): -
Apache or nginx version (eg, Apache 2.4.25): -
PHP version (eg, 5.6): -
Is this the first time youâve seen this error?: yes
Can you reliably replicate it? (If so, please outline steps): no
The issue you are facing: I can connect to the box over Putty, but i don see anything in my Internetexplorer. No Login Windows
The output of your Nextcloud log in Admin > Logging: ???
âpasswordsaltâ => âxxxâ,
âsecretâ => âxxxâ,
âtrusted_domainsâ =>
0 => âlocalhostâ,
1 => â192.168.xxx.xxâ,
2 => âxxx.spdns.deâ,
4 => âxxx.ddns.netâ,
âdatadirectoryâ => â/media/USBdrive/ncdataâ,
âoverwrite.cli.urlâ => âhttp://localhostâ,
âdbtypeâ => âmysqlâ,
âversionâ => â12.0.3.3â,
âdbnameâ => ânextcloudâ,
âdbhostâ => âlocalhostâ,
âdbportâ => ââ,
âdbtableprefixâ => âoc_â,
âdbuserâ => âncadminâ,
âdbpasswordâ => âownyourbitsâ,
âlogtimezoneâ => âUTCâ,
âinstalledâ => true,
âinstanceidâ => âxxxâ,
âmail_from_addressâ => âadminâ,
âmail_smtpmodeâ => âphpâ,
âmail_domainâ => âownyourbits.comâ,
âmaintenanceâ => false,
âmail_smtpauthtypeâ => âLOGINâ,
âthemeâ => ââ,
âloglevelâ => 2,
âmemcache.localâ => â\OC\Memcache\Redisâ,
âmemcache.lockingâ => â\OC\Memcache\Redisâ,
âredisâ =>
âhostâ => â/var/run/redis/redis.sockâ,
âportâ => 0,
âtimeoutâ => 0.0,
folder apache2 -> error.log
[Sat Nov 11 07:54:28.004205 2017] [mpm_event:notice] [pid 915:tid 1995395072] AH00489: Apache/2.4.25 (Raspbian) OpenSSL/1.0.2l configured â resuming normal operations
[Sat Nov 11 07:54:28.004374 2017] [core:notice] [pid 915:tid 1995395072] AH00094: Command line: â/usr/sbin/apache2â
