[SOLVED] Nextcloud-aio-mastercontainer wont start
    • AIO 31.0.10
    • Unraid 7.2.0
    • 8.3.26
    • Yes
    • After updating the nextcloud-aio-mastercontainer
    • AIO
nextcloud-aio-mastercontainer fails to start, so the AIO interface is not reachable.
  1. start nextcloud-aio-mastercontainer
  2. container fails
WARNING: No swap limit support
/usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
  import pkg_resources
{"level":"info","ts":1762164752.3667262,"msg":"maxprocs: Leaving GOMAXPROCS=16: CPU quota undefined"}
{"level":"info","ts":1762164752.3668618,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":60547560652,"previous":9223372036854775807}
{"level":"info","ts":1762164752.3668792,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1762164752.3676443,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1762164752.3707101,"msg":"serving initial configuration"}
[03-Nov-2025 10:12:32] NOTICE: fpm is running, pid 177
[03-Nov-2025 10:12:32] NOTICE: ready to handle connections
[Mon Nov 03 10:12:32.463926 2025] [mpm_event:notice] [pid 171:tid 171] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.4 configured -- resuming normal operations
[Mon Nov 03 10:12:32.463942 2025] [core:notice] [pid 171:tid 171] AH00094: Command line: 'httpd -D FOREGROUND'
[05-Nov-2025 09:19:08] NOTICE: Terminating ...
[05-Nov-2025 09:19:08] NOTICE: exiting, bye-bye!
[Wed Nov 05 09:19:10.527435 2025] [mpm_event:notice] [pid 171:tid 171] AH00491: caught SIGTERM, shutting down
curl: (6) Could not resolve host: ghcr.io
Trying to fix docker.sock permissions internally...
Creating docker group internally with id 281
The environmental variable TZ has been set which is not supported by AIO since it only supports running in the default Etc/UTC timezone!
The correct timezone can be set in the AIO interface later on!
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
Total reclaimed space: 0B
Could not reach https://ghcr.io.
Most likely is something blocking access to it.
You should be able to fix this by following https://dockerlabs.collabnix.com/intermediate/networking/Configuring_DNS.html
Another solution is using https://github.com/nextcloud/all-in-one/tree/main/manual-install
See https://github.com/nextcloud/all-in-one/blob/main/manual-install/latest.yml
It seems like you did not give the mastercontainer the correct name? (The 'nextcloud-aio-mastercontainer' container was not found.
PASTE
PASTE HERE
occ $ config:list system
    "one-click-instance": true,
    "memcache.local": "\\\\OC\\\\Memcache\\\\APCu",
    "apps_paths": \[
            "path": "\\/var\\/www\\/html\\/apps",
            "url": "\\/apps",
            "writable": false
            "path": "\\/var\\/www\\/html\\/custom_apps",
            "url": "\\/custom_apps",
            "writable": true
    "appsallowlist": false,
    "memcache.distributed": "\\\\OC\\\\Memcache\\\\Redis",
    "memcache.locking": "\\\\OC\\\\Memcache\\\\Redis",
    "redis": {
        "host": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
        "password": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
        "port": 6379
    "overwritehost": "nc.\*\*\*\*\*.com",
    "overwriteprotocol": "https",
    "passwordsalt": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "secret": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "trusted_domains": \[
        "localhost",
        "nc.\*\*\*\*\*.com"
    "datadirectory": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "dbtype": "pgsql",
    "version": "31.0.10.2",
    "overwrite.cli.url": "https:\\/\\/nc.\*\*\*\*\*.com\\/",
    "dbname": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "dbhost": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "dbport": "",
    "dbtableprefix": "oc\_",
    "dbuser": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "dbpassword": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "instanceid": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "loglevel": 2,
    "log_type": "file",
    "logfile": "\\/var\\/www\\/html\\/data\\/nextcloud.log",
    "log_rotate_size": "10485760",
    "log.condition": {
        "apps": \[
            "admin_audit"
    "preview_max_x": "2048",
    "preview_max_y": "2048",
    "jpeg_quality": "60",
    "enabledPreviewProviders": {
        "1": "OC\\\\Preview\\\\Image",
        "2": "OC\\\\Preview\\\\MarkDown",
        "3": "OC\\\\Preview\\\\MP3",
        "4": "OC\\\\Preview\\\\TXT",
        "5": "OC\\\\Preview\\\\OpenDocument",
        "6": "OC\\\\Preview\\\\Movie",
        "7": "OC\\\\Preview\\\\Krita",
        "0": "OC\\\\Preview\\\\Imaginary",
        "23": "OC\\\\Preview\\\\ImaginaryPDF"
    "enable_previews": true,
    "upgrade.disable-web": true,
    "mail_smtpmode": "smtp",
    "activity_expire_days": "30",
    "share_folder": "\\/Shared",
    "one-click-instance.link": "https:\\/\\/nextcloud.com\\/all-in-one\\/",
    "upgrade.cli-upgrade-link": "https:\\/\\/github.com\\/nextcloud\\/all-in-one\\/discussions\\/2726",
    "updatedirectory": "\\/nc-updater",
    "htaccess.RewriteBase": "\\/",
    "dbpersistent": false,
    "trusted_proxies": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "preview_imaginary_url": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "preview_imaginary_key": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "default_phone_region": "IL",
    "mail_from_address": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "mail_sendmailmode": "smtp",
    "mail_domain": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "mail_smtphost": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "mail_smtpport": "587",
    "mail_smtpauth": 1,
    "mail_smtpname": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "mail_smtppassword": "\*\*\*REMOVED SENSITIVE VALUE\*\*\*",
    "documentation_url.server_logs": "https:\\/\\/github.com\\/nextcloud\\/all-in-one\\/discussions\\/5425",
    "updatechecker": false,
    "app_install_overwrite": \[
        "files_external_gdrive",
        "extract"
    "DOMAIN": "nc.\*\*\*\*\*.com"
  • activity: 4.0.0
  • admin_audit: 1.21.0
  • app_api: 5.0.2
  • assistant: 2.9.0
  • bruteforcesettings: 4.0.0
  • calendar: 5.5.7
  • circles: 31.0.0
  • comments: 1.21.0
  • contacts: 7.3.5
  • contactsinteraction: 1.12.1
  • dashboard: 7.11.0
  • dav: 1.33.0
  • deck: 1.15.3
  • epubviewer: 1.8.1
  • external: 6.0.2
  • federation: 1.21.0
  • files: 2.3.1
  • files_antivirus: 6.0.7
  • files_autorename: 2.2.2
  • files_downloadlimit: 4.0.0
  • files_fulltextsearch: 31.0.0
  • files_lock: 31.0.2
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • flow_notifications: 2.0.1
  • forms: 5.2.2
  • fulltextsearch: 31.0.0
  • fulltextsearch_elasticsearch: 31.0.0
  • groupfolders: 19.1.8
  • integration_openai: 3.7.1
  • logreader: 4.0.0
  • news: 27.1.0
  • nextcloud-aio: 0.8.0
  • notes: 4.12.3
  • notifications: 4.0.0
  • notify_push: 1.2.1
  • oauth2: 1.19.1
  • occweb: 0.2.3
  • password_policy: 3.0.0
  • photos: 4.0.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • quota_warning: 1.22.0
  • recognize: 9.0.7
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • richdocuments: 8.7.6
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • spreed: 21.1.5
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • tasks: 0.17.0
  • text: 5.0.2
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • whiteboard: 1.4.1
  • workflow_media_converter: 1.15.1
  • workflowengine: 2.13.0
  • encryption: 2.19.0
  • extract: 1.3.6 (installed 1.3.6)
  • files_external: 1.23.0
  • files_external_gdrive: 0.4.0 (installed 0.4.0)
  • mail: 5.5.11 (installed 5.5.11)
  • shiftsnext: 2.0.0 (installed 2.0.0)
  • spgverein: 0.12.0 (installed 0.12.0)
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
Manually reinstalled the docker container and it fixed the issue.
