Hi all!
I am running Nextcloud in a container setup in FPM mode. The app container itself runs the php-fpm
component, I have an additional container running nginx as web server. I am following this example very closely:
This is my docker-compose.yml file:
nextcloud:
image: nextcloud:17.0.1-fpm-alpine
container_name: nextcloud
environment:
- REDIS_HOST=redis
- MYSQL_HOST=db
volumes:
- nextcloud-data:/var/www/html
depends_on:
- mariadb
- redis
env_file:
- ./config/mariadb_nextcloud.env
nextcloud-web:
build: ./nextcloud-web
container_name: nextcloud-web
restart: always
volumes:
- nextcloud-data:/var/www/html:ro
environment:
- VIRTUAL_HOST={{ nextcloud_external_url }}
- VIRTUAL_PORT=80
- LETSENCRYPT_HOST={{ nextcloud_external_url }}
depends_on:
- nextcloud
This is the nginx.conf
file that gets copied into the nextcloud-web container (based on Nginx, no further changes except for adding the config file):
worker_processes auto;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
set_real_ip_from 10.0.0.0/8;
set_real_ip_from 172.16.0.0/12;
set_real_ip_from 192.168.0.0/16;
real_ip_header X-Real-IP;
#gzip on;
upstream php-handler {
server nextcloud:9000;
server {
listen 80;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/html;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
# The following rule is only needed for the Social app.
#rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
return 301 $scheme://$host:$server_port/remote.php/dav;
# set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
# fastcgi_param HTTPS on;
# Avoid sending the security headers twice
# Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js, css and map files
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)$ {
# Optional: Don't log access to other assets
access_log off;
This is pretty much the standard configuration from the link above. In front of this container I’m using the well-known Nginx-proxy
container with letsencrypt companion. Most of the Nextcloud installation works (web frontend, upload / download, the apps, most of the admin portal). I however recently installed a custom app (SAML configuration) and the management page of this does not load, but instead gives me loads of the following errors:
Content Security Policy: The page's settings blocked the loading of a resource at inline ("script-src").
The resource from “https://<my-url>.tld/apps/files/” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
Any idea what’s going on here? Any help would be appreciated.
