Hallo!
Kann mir jemand sagen was folgender Fehlercode aussagt?
sudo -u http /bin/php /volume1/web/nextcloud/occ
exception âDoctrine\DBAL\DBALExceptionâ with message âFailed to connect to the database: An exception occured in driver: could not find driverâ in /volume1/web/nextcloud/lib/private/DB/Connection.php:59
Stack trace:
#0 /volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /volume1/web/nextcloud/lib/private/DB/Connection.php(142): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /volume1/web/nextcloud/lib/private/DB/ConnectionFactory.php(123): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /volume1/web/nextcloud/lib/private/Server.php(415): OC\DB\ConnectionFactory->getConnection(âmysqlâ, Array)
#8 /volume1/web/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#9 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet(âDatabaseConnectâŠâ)
#10 /volume1/web/nextcloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query(âDatabaseConnectâŠâ)
#11 /volume1/web/nextcloud/lib/private/Server.php(1029): OC\ServerContainer->query(âDatabaseConnectâŠâ)
#12 /volume1/web/nextcloud/lib/private/Server.php(220): OC\Server->getDatabaseConnection()
#13 /volume1/web/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#14 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet(âOC\AuthenticatiâŠâ)
#15 /volume1/web/nextcloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query(âOC\AuthenticatiâŠâ)
#16 /volume1/web/nextcloud/lib/private/Server.php(224): OC\ServerContainer->query(âOC\AuthenticatiâŠâ)
#17 /volume1/web/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#18 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet(âOC\AuthenticatiâŠâ)
#19 /volume1/web/nextcloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query(âOC\AuthenticatiâŠâ)
#20 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(151): OC\ServerContainer->query(âOC\AuthenticatiâŠâ)
#21 /volume1/web/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(109): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#22 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet(âOC\AuthenticatiâŠâ)
#23 /volume1/web/nextcloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query(âOC\AuthenticatiâŠâ)
#24 /volume1/web/nextcloud/lib/private/Server.php(239): OC\ServerContainer->query(âOC\AuthenticatiâŠâ)
#25 /volume1/web/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#26 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet(âUserSessionâ)
#27 /volume1/web/nextcloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query(âUserSessionâ)
#28 /volume1/web/nextcloud/lib/private/Server.php(906): OC\ServerContainer->query(âUserSessionâ)
#29 /volume1/web/nextcloud/lib/private/Server.php(459): OC\Server->getUserSession()
#30 /volume1/web/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#31 /volume1/web/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet(âAppManagerâ)
#32 /volume1/web/nextcloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query(âAppManagerâ)
#33 /volume1/web/nextcloud/lib/private/Server.php(1206): OC\ServerContainer->query(âAppManagerâ)
#34 /volume1/web/nextcloud/lib/private/legacy/app.php(293): OC\Server->getAppManager()
#35 /volume1/web/nextcloud/lib/private/legacy/app.php(109): OC_App::getEnabledApps()
#36 /volume1/web/nextcloud/lib/base.php(658): OC_App::loadApps(Array)
#37 /volume1/web/nextcloud/lib/base.php(1059): OC::init()
#38 /volume1/web/nextcloud/console.php(48): require_once(â/volume1/web/neâŠâ)
#39 /volume1/web/nextcloud/occ(11): require_once(â/volume1/web/neâŠâ)
#40 {main}
Vielen Dank und lieben GruĂ,
JD
