I’m getting ERR_CONNECTION_REFUSED when trying to access NC internal to my network using my domain name “https://xxxxnextcloud.mywire.org/nextcloud/”.
However, it works as intended when accessing NC outside my network.
My setup is as follows:
- DDNS, TLS and reverse proxy is handled through pfsense.
2 I have a piHole setup internal to my network and I have created a local DNS record pointing my domain name “https://xxxxnextcloud.mywire.org/nextcloud/” - 192.168.140.180 (NC server) - NC config file looks as follows:
- tracert internal to my network looks fine (see below):
If I try to access NC internal to my network using the below url it works:
http://xxxxnextcloud.mywire.org/nextcloud/index.php/login
I’m at a lost at the moment as to why it’s not working.
