Nextcloud version: 26.0.5 (nextcloud:stable docker image)
Operating system and version: Debian 21.1 (host machine)
Apache or nginx version: caddy reverse proxy (running on host machine)
PHP version: 8.2.10
Installed via docker-compose (see below).
I’m getting a lot of what seem to be DNS related errors from my new docker nextcloud install, and parts of the application ( Security & setup warnings, App store) are not working properly.
I can access the nextcloud site, I have created an admin account and installed the recommended apps.
curl https://apps.nextcloud.com
works on the host machine, the same command from within the nextcloud image returns the error:
curl: (6) Could not resolve host: apps.nextcloud.com
Docker compose file:
version: '2'
services:
db:
container_name: nextcloud_db
image: mariadb:10.6
restart: always
command: --transaction-isolation=READ-COMMITTED --log-bin=binlog --binlog-format=ROW
volumes:
- /srv/volumes/nextcloud/db:/var/lib/mysql
environment:
MYSQL_ROOT_PASSWORD:
MYSQL_DATABASE: nextcloud
MYSQL_USER: nextcloud
MYSQL_PASSWORD:
networks:
- nextcloud
app:
image: nextcloud:stable
restart: always
dns:
- 1.1.1.1
labels:
caddy: nextcloud-dev.mywebsite.com
caddy.reverse_proxy: "{{upstreams}}"
caddy.header: /*
caddy.header.Strict-Transport-Security: '"max-age=15552000;"'
caddy.rewrite_0: /.well-known/carddav /remote.php/dav
caddy.rewrite_1: /.well-known/caldav /remote.php/dav
volumes:
- /srv/volumes/nextcloud/app:/var/www/html
environment:
MYSQL_PASSWORD:
MYSQL_HOST: db
NEXTCLOUD_TRUSTED_DOMAINS: nextcloud-dev.mywebsite.com
ports:
- 127.0.0.1:8080:80
links:
- db
networks:
- nextcloud
volumes:
db:
nextcloud:
networks:
nextcloud:
Caddyfile:
nextcloud-dev.mywebsite.com {
rewrite /.well-known/carddav /remote.php/dav
rewrite /.well-known/caldav /remote.php/dav
reverse_proxy 127.0.0.1:8080
cat /etc/resolv.conf from the image:
nameserver 127.0.0.11
options ndots:0
Security & setup warning:
This server has no working internet connection: Multiple endpoints could not be reached. This means that some of the features like mounting external storage, notifications about updates or installation of third-party apps will not work. Accessing files remotely and sending of notification emails might not work, either. Establish a connection from this server to the internet to enjoy all features.
Is this the first time you’ve seen this error? Yes, but it happens every time on first install.
- docker-compose up
- Try to access apps
- view logs
[PHP] Error: dns_get_record(): A temporary server error occurred. at /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php#58
GET /settings/ajax/checksetup
from 172.18.0.1 by admin at 2023-09-14T12:46:12+00:00
[appstoreFetcher] Warning: GuzzleHttp\Exception\RequestException: cURL error 49: Couldn't parse CURLOPT_RESOLVE entry 'apps.nextcloud.com:80:' (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json at <<closure>>
0. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 158
GuzzleHttp\Handler\CurlFactory::createRejection("*** sensitive parameters replaced ***")
1. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 110
GuzzleHttp\Handler\CurlFactory::finishError(["GuzzleHttp\\Handler\\CurlHandler"], "*** sensitive parameters replaced ***", ["GuzzleHttp\\Handler\\CurlFactory"])
2. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php line 47
GuzzleHttp\Handler\CurlFactory::finish(["GuzzleHttp\\Handler\\CurlHandler"], "*** sensitive parameters replaced ***", ["GuzzleHttp\\Handler\\CurlFactory"])
3. /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php line 150
GuzzleHttp\Handler\CurlHandler->__invoke("*** sensitive parameters replaced ***", "*** sensitive parameters replaced ***")
4. /var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php line 35
OC\Http\Client\DnsPinMiddleware->OC\Http\Client\{closure}("*** sensitive parameters replaced ***")
5. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 31
GuzzleHttp\PrepareBodyMiddleware->__invoke("*** sensitive parameters replaced ***", "*** sensitive parameters replaced ***")
6. /var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php line 71
GuzzleHttp\Middleware::GuzzleHttp\{closure}("*** sensitive parameters replaced ***")
7. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 63
GuzzleHttp\RedirectMiddleware->__invoke("*** sensitive parameters replaced ***", "*** sensitive parameters replaced ***")
8. /var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php line 75
9. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php line 331
GuzzleHttp\HandlerStack->__invoke("*** sensitive parameters replaced ***", "*** sensitive parameters replaced ***")
10. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php line 168
GuzzleHttp\Client->transfer("*** sensitive parameters replaced ***", "*** sensitive parameters replaced ***")
11. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php line 187
GuzzleHttp\Client->requestAsync("*** sensitive parameters replaced ***")
12. /var/www/html/lib/private/Http/Client/Client.php line 226
GuzzleHttp\Client->request("*** sensitive parameters replaced ***", "https://apps.ne ... n", ["/var/www/html/ ... "])
13. /var/www/html/lib/private/App/AppStore/Fetcher/Fetcher.php line 120
OC\Http\Client\Client->get("https://apps.ne ... n", [60])
14. /var/www/html/lib/private/App/AppStore/Fetcher/AppFetcher.php line 86
OC\App\AppStore\Fetcher\Fetcher->fetch("", "")
15. /var/www/html/lib/private/App/AppStore/Fetcher/Fetcher.php line 190
OC\App\AppStore\Fetcher\AppFetcher->fetch("", "", false)
16. /var/www/html/lib/private/App/AppStore/Fetcher/AppFetcher.php line 187
OC\App\AppStore\Fetcher\Fetcher->get(false)
17. /var/www/html/lib/private/Installer.php line 421
OC\App\AppStore\Fetcher\AppFetcher->get(false)
18. /var/www/html/apps/settings/lib/Controller/AppSettingsController.php line 264
OC\Installer->isUpdateAvailable("systemtags")
19. <<closure>>
OCA\Settings\Controller\AppSettingsController->OCA\Settings\Controller\{closure}("*** sensitive parameters replaced ***")
20. /var/www/html/apps/settings/lib/Controller/AppSettingsController.php line 256
array_map(["Closure"], ["*** sensitive ... "])
21. /var/www/html/lib/private/AppFramework/Http/Dispatcher.php line 230
OCA\Settings\Controller\AppSettingsController->listApps()
22. /var/www/html/lib/private/AppFramework/Http/Dispatcher.php line 137
OC\AppFramework\Http\Dispatcher->executeController(["OCA\\Settings\ ... "], "listApps")
23. /var/www/html/lib/private/AppFramework/App.php line 183
OC\AppFramework\Http\Dispatcher->dispatch(["OCA\\Settings\ ... "], "listApps")
24. /var/www/html/lib/private/Route/Router.php line 315
OC\AppFramework\App::main("OCA\\Settings\\ ... r", "listApps", ["OC\\AppFramewo ... "], ["settings.AppSettings.listApps"])
25. /var/www/html/lib/base.php line 1065
OC\Route\Router->match("/settings/apps/list")
26. /var/www/html/index.php line 36
OC::handleRequest()
GET /settings/apps/list
from 172.18.0.1 by admin at 2023-09-14T12:44:51+00:00
[PHP] Error: dns_get_record(): A temporary server error occurred. at /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php#84
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => 'nextcloud-dev.mywebsite.com',
'version' => '26.0.5.1',
'overwrite.cli.url' => 'http://nextcloud-dev.mywebsite.com',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'nextcloud',
'dbpassword' => ,
I’ve searched the forum but couldn’t find a conclusive answer. Any ideas would be gratefully accepted.
