example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.0.3
Operating system and version (eg, Ubuntu 17.04): Alpine Linux 3.8
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.14.0
PHP version (eg, 7.1): 7.2.11
I want to add NC address book in CardBook (Thunderbird) following the instructions in the guide.
However connection test in CardBook fails.
- Create app password in user settings -> security
- Confirm created user app password
- Start connection to NC’s address book using user account + app password
No server logs available
'passwordsalt' => 'DXBA0P/zwcxxxxxxxxxxxxxxxxxxxx',
'secret' => 'FHn9DNilPSXs0azIC4xuZQw5DDBQxxxxxxxxxxxxxxxxxxxx',
0 => '<mydomain>.de',
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
'datadirectory' => '/var/lib/nextcloud/data',
'logfile' => '/var/log/nextcloud//nextcloud.log',
'loglevel' => 2,
'knowledgebaseenabled' => true,
'check_for_working_htaccess' => false,
'version' => '14.0.3.0',
'overwrite.cli.url' => 'https://<mydomain>.de',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nc',
'dbpassword' => 'xxxxxxxxxxxx',
'mail_from_address' => 'admin',
'mail_smtpmode' => 'smtp',
'mail_domain' => '<FQHN>',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpport' => '587',
'mail_smtpname' => '<user>',
'mail_smtppassword' => '<password>',
'instanceid' => 'xxxxxxxxxxx',
'redis' =>
'host' => '/run/redis/redis.sock',
'port' => 0,
'timeout' => 0,
nothing relevant
The application CardBook is reporting this error:
https://<mydomain>.de/remote.php/dav/addressbooks/users/<account>/contacts/
[HTTP/1.1 503 Service Unavailable 31ms]
Kopfzeilen
Antwort
Cookies
Cache-Controlno-store, no-cache, must-revalidateConnectioncloseContent-Security-Policydefault-src 'self'; script-src 'self' 'unsafe-eval' 'nonce-TW8zQ2w1R0dIWmt3SlZ6QVpJNHprMDZoemNtWHVhaHB4QUpOZ1dkZHVXUT06Zjg2SXpxQzBkY3BFVHl1ckh2bDNwRHlRL2Z2RzdNRTZoem9MMFFsdDhnbz0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';Content-Typetext/html; charset=UTF-8DateSat, 27 Oct 2018 11:52:21 GMTExpiresThu, 19 Nov 1981 08:52:00 GMTPragmano-cacheServernginxSet-Cookie__Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=laxSet-Cookie__Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strictStrict-Transport-Securitymax-age=15768000Transfer-EncodingchunkedX-Frame-OptionsSAMEORIGIN
Accept*/*Accept-Encodinggzip, deflate, brAccept-Languagede,en-US;q=0.7,en;q=0.3AuthorizationBasic dGhvbWFzOmlGNEprLTRhTm95LWNQbVJ0LUdkOUtULU5vQ055Connectionkeep-aliveContent-Length128Cookieochentz7kvhd=d620emojeqmq6gutaill01gvo7; oc_sessionPassphrase=b%2Fjbfd%2BuZzAtoQZ0fg6DhdQarpzM8ODB8e6vMmE0E2sMnIvVBeoINsVrfXwKq6zibAzhPUWrENSNF%2FUncQG9UcPcq2oRWRbbQM5toCNIYmjAGn8eUcNh3ul7MXMBrpta; SERVERID=srv03Host<mydomain>.deUser-AgentThunderbird CardBook/32.5 Lightning/6.2.2.1content-typeapplication/xml; charset=utf-8depth1
