JoergP
#1
Tried to configure the add-in, but no success.
The Thunderbird error console shows the following response (return code 404):
“The requested URL /owncloud:443/ocs/v1.php/cloud/user was not found on this server.”
The user credentials are definitely ok (user exists, password correct).
Any hint is appreciated!
JoergP
#2
never mind … got it working.
- downloaded the newest code from github
- re-packed the src folder to a zip file
- re-named the zip to xpi
- installed in my Thunderbird
The version bumped to v1.7, on the Mozilla sites there was only v1.5.
With this version the configuration works as expected.
