After my recent run of ncp-update-nextcloud (of course on the nextcloudpi webpage), the process crashed and now I receive the usual “Internal Server Error” message. Running systemctl status -l mariadb I get the following error message:
And what error do you get in detail? Is it related to the DB?
The last line is just a warning, looks more like connection 4 is aborted, but there are not more details, if e.g. the max number of connections is reached.
You can use the arrow keys to scroll to right when lines are cut off. Or you can use journalctl with the --no-pager option to get an output with line breaks.
What do I need to do to dig deeper into the potential error? @tflidd & @bb77
In addition, I tried running sudo -u www-data php8.1 occ maintenance:repair but it resulted in a lot of errors which seem to relate to the nextloud tables not being available/accessible. This seems to be in line with the aborted connection to the db. Correct?
@bb77 Thanks for your feedback - I yet again learned something. By the way your first two comments miss a hyphen between no and pager, as I learned. Just if others might read this post.
I restored a backup of my Nextcloud instance (about 2 days old) and got everything working again. I do not know, what the exact error during the update was, but I can only recommend using all the backup possibilities of NCpi.
