Hi community
example
longer
example
here
Nextcloud version (eg, 29.0.5): 25.0.13
Operating system and version (eg, Ubuntu 29.04): Linux 5.14.0-427.16.1.el9_4.x86_64 x86_64
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 8.3): replace me
The issue you are facing: In the company i work for, we are working some days from home, those days the employees have to connect via VPN to make a proper syncing of their files with nextcloud, i need a way to track if the employees are syncing their files. thx for your answers
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
