Nextcloud version 26.0.1
Operating system and version Ubuntu 20.04)
Apache or nginx version Apache 2.4.41
PHP version 8.0.30
We have several users successfully connecting to (clustered) shares on a Windows 2012R2 fileserver cluster. We recently had to replace one node in the cluster and since Windows 2012R2 is coming to it’s end of life, we decided that it was a good time to start a rolling update by introducing a new server running Windows 2016. This configuration works, all clustered disks can be moved between 2012R2 node and 2016 node and shares remain online.
However, when the disks and fileserver role is moved to the 2016 server, Nextcloud fails to connect to shares.
Is this the first time you’ve seen this error? Y
- Move all disk and fileserver role to new Windows 2016 server
- Try to connect to existing shares as defined in Nextcloud
- Moving roles and disks back to Windows 2012R2 node and connection to SMB share succeeds
config.php file
'passwordsalt' => '...',
'secret' => '...',
0 => 'localhost',
1 => '...',
2 => '...',
'datadirectory' => '/var/ncdata',
'overwrite.cli.url' => 'https://.../',
'version' => '26.0.1.1',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbtableprefix' => '...',
'dbuser' => '...',
'dbpassword' => '...',
'logtimezone' => 'UTC',
'default_phone_region' => '...',
'instanceid' => '...',
'appstore.experimental.enabled' => 'true',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => '...',
'mail_from_address' => 'noreply',
'mail_domain' => '...',
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0,
'dbindex' => 0,
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'loglevel' => 0,
'theme' => '',
'encryption.legacy_format_support' => false,
'encryption.key_storage_migrated' => false,
{"reqId":"gw1Hstc2XViSilUcO9gO","level":2,"time":"2023-09-04T12:24:56+00:00","remoteAddr":"...","user":"...","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/.../","message":"External storage not available: Invalid request for /... (InvalidArgumentException)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36","version":"26.0.1.1","exception":{"Exception":"Icewind\\SMB\\Exception\\InvalidArgumentException","Message":"Invalid request for /... (InvalidArgumentException)","Code":22,"Trace":[{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php","line":75,"function":"fromMap","class":"Icewind\\SMB\\Exception\\Exception","type":"::"},{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php","line":92,"function":"handleError","class":"Icewind\\SMB\\Native\\NativeState","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php","line":351,"function":"testResult","class":"Icewind\\SMB\\Native\\NativeState","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php","line":305,"function":"getxattr","class":"Icewind\\SMB\\Native\\NativeState","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php","line":43,"function":"getAttribute","class":"Icewind\\SMB\\Native\\NativeShare","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php","line":69,"function":"stat","class":"Icewind\\SMB\\Native\\NativeFileInfo","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php","line":114,"function":"getSize","class":"Icewind\\SMB\\Native\\NativeFileInfo","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php","line":191,"function":"stat","class":"Icewind\\SMB\\Native\\NativeShare","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php","line":348,"function":"getFileInfo","class":"OCA\\Files_External\\Lib\\Storage\\SMB","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Common.php","line":462,"function":"stat","class":"OCA\\Files_External\\Lib\\Storage\\SMB","type":"->"},{"file":"/var/www/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php","line":729,"function":"test","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":471,"function":"test","class":"OCA\\Files_External\\Lib\\Storage\\SMB","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php","line":69,"function":"test","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php","line":83,"function":"updateAvailability","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php","line":92,"function":"isAvailable","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php","line":445,"function":"checkAvailability","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":116,"function":"getMetaData","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":153,"function":"getData","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1509,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","line":101,"function":"getDirectoryContent","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":262,"function":"getDirectoryListing","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/TagsPlugin.php","line":227,"function":"getChildren","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\TagsPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":366,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Exception/Exception.php","Line":44,"message":"External storage not available: Invalid request for /... (InvalidArgumentException)","exception":{},"CustomMessage":"External storage not available: Invalid request for /... (InvalidArgumentException)"}}
Any help would greatly appreciated.
Kind Regards,
Heine
