A SAMBA File Server is joined to a domain controller. Nextcloud uses LDAP (the same domain controller) for user/password queries and accesses the samba file server via External Storag SMB/CIFS
Authentication is set to “Login credentials saved in database”.
After some time and if the browser tab was closed the mounted folders disappear. This happens also on the Android App.
In the log the following entries show up:
OCP\Files\StorageNotAvailableException: Storage with mount id 8 is not available at
The Workaround is to logout and login again. Now all the shares are accessible again.
Nextcloud version: 26.05
Operating system and version : Docker Image
Apache or nginx version: 2.4.57
PHP version: 8.2.8
Nextlcoud Config
“system”: {
“htaccess.RewriteBase”: “/”,
“memcache.local”: “\OC\Memcache\APCu”,
“apps_paths”: [
“path”: “/var/www/html/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/html/custom_apps”,
“url”: “/custom_apps”,
“writable”: true
“instanceid”: “REMOVED SENSITIVE VALUE”,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“172.17.0.1:7080”,
“cloud.yyy.yy”,
“192.168.222.*”
“forwarded_for_headers”: [
“HTTP_X_FORWARDED_FOR”
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “26.0.5.1”,
“overwrite.cli.url”: “http://192.168.222.11:7080”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“theme”: “”,
“loglevel”: 2,
“maintenance”: false,
“default_phone_region”: “DE”,
“allow_local_remote_servers”: true,
“trusted_proxies”: “REMOVED SENSITIVE VALUE”,
“mail_smtpmode”: “smtp”,
“mail_smtphost”: “REMOVED SENSITIVE VALUE”,
“mail_smtpport”: “587”,
“mail_smtpsecure”: “tls”,
“mail_smtpauth”: true,
“mail_smtpauthtype”: “plain”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_from_address”: “REMOVED SENSITIVE VALUE”,
“mail_domain”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”
“apps”: {
“activity”: {
“enabled”: “yes”,
“installed_version”: “2.18.0”,
“notify_email_calendar”: “1”,
“notify_email_calendar_event”: “0”,
“notify_email_calendar_todo”: “0”,
“notify_email_contacts”: “0”,
“notify_email_favorite”: “0”,
“notify_email_file_changed”: “0”,
“notify_email_file_favorite_changed”: “0”,
“notify_email_group_settings”: “1”,
“notify_email_public_links”: “1”,
“notify_email_remote_share”: “0”,
“notify_email_shared”: “1”,
“notify_email_systemtags”: “0”,
“notify_notification_calendar”: “0”,
“notify_notification_calendar_event”: “0”,
“notify_notification_calendar_todo”: “0”,
“notify_notification_contacts”: “0”,
“notify_notification_favorite”: “0”,
“notify_notification_file_changed”: “0”,
“notify_notification_file_favorite_changed”: “0”,
“notify_notification_group_settings”: “1”,
“notify_notification_personal_settings”: “0”,
“notify_notification_public_links”: “0”,
“notify_notification_remote_share”: “0”,
“notify_notification_security”: “1”,
“notify_notification_shared”: “0”,
“notify_notification_systemtags”: “0”,
“notify_setting_batchtime”: “3600”,
“notify_setting_self”: “0”,
“notify_setting_selfemail”: “0”,
“types”: “filesystem”
“admin_audit”: {
“enabled”: “yes”,
“installed_version”: “1.16.0”,
“types”: “logging”
“audioplayer”: {
“enabled”: “no”,
“installed_version”: “3.1.0”,
“backgroundjob”: {
“lastjob”: “1833”
“bruteforcesettings”: {
“enabled”: “yes”,
“installed_version”: “2.6.0”,
“types”: “”
“calendar”: {
“enabled”: “yes”,
“installed_version”: “4.4.4”,
“types”: “”
“circles”: {
“enabled”: “no”,
“installed_version”: “26.0.0”,
“loopback_tmp_scheme”: “http”,
“maintenance_run”: “0”,
“maintenance_update”: “{"maximum":3,"3":1691492700,"2":1691495100,"1":1691495400,"4":1657936801,"5":1657940401}”,
“migration_22”: “1”,
“migration_22_1”: “1”,
“migration_run”: “0”,
“types”: “filesystem,dav”
“cloud_federation_api”: {
“enabled”: “yes”,
“installed_version”: “1.9.0”,
“comments”: {
“enabled”: “no”,
“installed_version”: “1.10.0”,
“types”: “logging”
“contacts”: {
“allowSocialSync”: “no”,
“enabled”: “yes”,
“installed_version”: “5.3.2”,
“types”: “dav”
“contactsinteraction”: {
“enabled”: “no”,
“installed_version”: “1.1.0”,
“types”: “dav”
“core”: {
“backgroundjobs_mode”: “cron”,
“emailTestSuccessful”: “1”,
“installed.bundles”: “["CoreBundle","CoreBundle"]”,
“installedat”: “1691497314.5953”,
“lastcron”: “1693215000”,
“lastupdateResult”: “{"version":"27.0.2.1","versionstring":"Nextcloud 27.0.2","url":"https:\/\/download.nextcloud.com\/server\/releases\/nextcloud-27.0.2.zip","web":"https:\/\/docs.nextcloud.com\/server\/27\/admin_manual\/maintenance\/upgrade.html","changes":"https:\/\/updates.nextcloud.com\/changelog_server\/?version=27.0.2","autoupdater":"1","eol":"0"}”,
“lastupdatedat”: “1693213071”,
“moveavatarsdone”: “yes”,
“oc.integritycheck.checker”: “[]”,
“previewsCleanedUp”: “1”,
“public_files”: “files_sharing/public.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”,
“shareapi_default_expire_date”: “no”,
“shareapi_default_internal_expire_date”: “yes”,
“shareapi_enforce_internal_expire_date”: “yes”,
“shareapi_enforce_links_password”: “yes”,
“shareapi_internal_expire_after_n_days”: “30”,
“theming.variables”: “d41d8cd98f00b204e9800998ecf8427e”,
“updater.secret.created”: “1691662416”,
“vendor”: “nextcloud”
“dashboard”: {
“enabled”: “yes”,
“installed_version”: “7.6.0”,
“types”: “”
“dav”: {
“buildCalendarReminderIndex”: “yes”,
“buildCalendarSearchIndex”: “yes”,
“builtSocialSearchIndex”: “yes”,
“chunks_migrated”: “1”,
“enabled”: “yes”,
“installed_version”: “1.25.0”,
“regeneratedBirthdayCalendarsForYearFix”: “yes”,
“federatedfilesharing”: {
“enabled”: “yes”,
“types”: “”
“federation”: {
“enabled”: “no”,
“installed_version”: “1.10.1”,
“types”: “authentication”
“files”: {
“cronjob_scan_files”: “500”,
“enabled”: “yes”,
“installed_version”: “1.21.1”,
“files_downloadactivity”: {
“enabled”: “yes”,
“files_external”: {
“allow_user_mounting”: “no”,
“enabled”: “yes”,
“installed_version”: “1.18.0”,
“types”: “filesystem”,
“user_mounting_backends”: “ftp,dav,owncloud,sftp,amazons3,swift,smb,\OC\Files\Storage\SFTP_Key,\OC\Files\Storage\SMB_OC”
“files_pdfviewer”: {
“enabled”: “yes”,
“installed_version”: “2.7.0”,
“types”: “”
“files_rightclick”: {
“enabled”: “yes”,
“installed_version”: “1.5.0”,
“types”: “”
“files_sharing”: {
“enabled”: “yes”,
“files_trashbin”: {
“enabled”: “no”,
“installed_version”: “1.11.0”,
“files_versions”: {
“enabled”: “no”,
“installed_version”: “1.13.0”,
“firstrunwizard”: {
“enabled”: “no”,
“installed_version”: “2.9.0”,
“types”: “logging”
“holiday_calendars”: {
“enabled”: “no”,
“installed_version”: “0.3.0”,
“types”: “”
“logreader”: {
“enabled”: “yes”,
“installed_version”: “2.11.0”,
“levels”: “00111”,
“types”: “”
“lookup_server_connector”: {
“enabled”: “yes”,
“installed_version”: “1.14.0”,
“mail”: {
“enabled”: “no”,
“installed_version”: “3.2.5”,
“types”: “”
“nextcloud_announcements”: {
“enabled”: “no”,
“pub_date”: “Thu, 24 Oct 2019 00:00:00 +0200”,
“types”: “logging”
“notes”: {
“enabled”: “yes”,
“installed_version”: “4.8.1”,
“types”: “”
“notifications”: {
“enabled”: “yes”,
“installed_version”: “2.14.0”,
“types”: “logging”
“oauth2”: {
“enabled”: “yes”,
“installed_version”: “1.14.1”,
“password_policy”: {
“enabled”: “no”,
“photos”: {
“enabled”: “yes”,
“installed_version”: “2.2.0”,
“lastPlaceMappedUser”: “80988C0B-7756-417D-B48C-52EE28FD9E1B”,
“lastPlaceMappingDone”: “true”,
“types”: “dav,authentication”
“privacy”: {
“enabled”: “yes”,
“readableLocation”: “ch”,
“types”: “”
“provisioning_api”: {
“enabled”: “yes”,
“types”: “prevent_group_restriction”
“recommendations”: {
“enabled”: “no”,
“installed_version”: “0.8.0”,
“types”: “”
“related_resources”: {
“enabled”: “yes”,
“types”: “”
“richdocuments”: {
“disable_certificate_verification”: “yes”,
“enabled”: “yes”,
“installed_version”: “8.0.3”,
“types”: “prevent_group_restriction”,
“wopi_url”: “http://192.168.222.11:7080/custom_apps/richdocumentscode/proxy.php?req=”
“richdocumentscode”: {
“enabled”: “yes”,
“installed_version”: “23.5.202”,
“types”: “”
“serverinfo”: {
“cached_count_filecache”: “1867920”,
“cached_count_storages”: “66”,
“enabled”: “yes”,
“types”: “”
“settings”: {
“enabled”: “yes”,
“installed_version”: “1.8.0”,
“types”: “”
“sharebymail”: {
“enabled”: “no”,
“spreed”: {
“enabled”: “no”,
“has_reference_id”: “yes”,
“installed_version”: “16.0.5”,
“project_access_invalidated”: “1”,
“signaling_token_privkey_es256”: “REMOVED SENSITIVE VALUE”,
“signaling_token_pubkey_es256”: “REMOVED SENSITIVE VALUE”,
“stun_servers”: “REMOVED SENSITIVE VALUE”,
“types”: “dav,prevent_group_restriction”
“support”: {
“enabled”: “no”,
“installed_version”: “1.3.0”,
“types”: “session”
“survey_client”: {
“enabled”: “no”,
“types”: “”
“suspicious_login”: {
“enabled”: “no”,
“installed_version”: “4.4.0”,
“systemtags”: {
“enabled”: “no”,
“types”: “logging”
“tasks”: {
“enabled”: “yes”,
“installed_version”: “0.15.0”,
“types”: “”
“text”: {
“enabled”: “yes”,
“installed_version”: “3.7.2”,
“types”: “dav”
“theming”: {
“cachebuster”: “2”,
“enabled”: “no”,
“installed_version”: “2.1.1”,
“name”: “Marco’s Cloud”,
“types”: “logging”,
“url”: “REMOVED SENSITIVE VALUE”
“twofactor_backupcodes”: {
“enabled”: “yes”,
“installed_version”: “1.15.0”,
“types”: “”
“updatenotification”: {
“audioplayer”: “3.2.1”,
“calendar”: “4.4.4”,
“contacts”: “5.3.2”,
“core”: “27.0.2.1”,
“enabled”: “yes”,
“mail”: “1.10.3”,
“related_resources”: “1.0.4”,
“richdocuments”: “7.1.4”,
“tasks”: “0.15.0”,
“types”: “”,
“update_check_errors”: “0”
“user_ldap”: {
“background_sync_interval”: “43200”,
“background_sync_offset”: “0”,
“background_sync_prefix”: “s02”,
“cleanUpJobOffset”: “0”,
“enabled”: “yes”,
“s02_lastChange”: “1692258883”,
“s02has_memberof_filter_support”: “1”,
“s02home_folder_naming_rule”: “”,
“s02last_jpegPhoto_lookup”: “0”,
“s02ldap_agent_password”: “REMOVED SENSITIVE VALUE”,
“s02ldap_attributes_for_group_search”: “”,
“s02ldap_attributes_for_user_search”: “”,
“s02ldap_backup_host”: “”,
“s02ldap_backup_port”: “”,
“s02ldap_base”: “DC=trautes,DC=heim”,
“s02ldap_base_groups”: “DC=trautes,DC=heim”,
“s02ldap_base_users”: “DC=trautes,DC=heim”,
“s02ldap_cache_ttl”: “600”,
“s02ldap_configuration_active”: “1”,
“s02ldap_default_ppolicy_dn”: “”,
“s02ldap_display_name”: “displayname”,
“s02ldap_dn”: “CN=ldap_bind,CN=Users,DC=trautes,DC=heim”,
“s02ldap_dynamic_group_member_url”: “”,
“s02ldap_email_attr”: “mail”,
“s02ldap_experienced_admin”: “0”,
“s02ldap_expert_username_attr”: “”,
“s02ldap_expert_uuid_group_attr”: “”,
“s02ldap_expert_uuid_user_attr”: “”,
“s02ldap_ext_storage_home_attribute”: “”,
“s02ldap_gid_number”: “gidNumber”,
“s02ldap_group_display_name”: “cn”,
“s02ldap_group_filter”: “(|(cn=Cloud Users))”,
“s02ldap_group_filter_mode”: “0”,
“s02ldap_group_member_assoc_attribute”: “gidNumber”,
“s02ldap_groupfilter_groups”: “Cloud Users”,
“s02ldap_groupfilter_objectclass”: “”,
“s02ldap_host”: “dc.trautes.heim”,
“s02ldap_login_filter”: “(&(|(|(memberof=CN=Cloud Users,CN=Users,DC=trautes,DC=heim)(primaryGroupID=1104)))(|(samaccountname=%uid)(|(mailPrimaryAddress=%uid)(mail=%uid))(|(sAMAccountName=%uid))))”,
“s02ldap_login_filter_mode”: “0”,
“s02ldap_loginfilter_attributes”: “sAMAccountName”,
“s02ldap_loginfilter_email”: “1”,
“s02ldap_loginfilter_username”: “1”,
“s02ldap_matching_rule_in_chain_state”: “unknown”,
“s02ldap_nested_groups”: “0”,
“s02ldap_override_main_server”: “”,
“s02ldap_paging_size”: “500”,
“s02ldap_port”: “389”,
“s02ldap_quota_attr”: “”,
“s02ldap_quota_def”: “”,
“s02ldap_tls”: “0”,
“s02ldap_turn_off_cert_check”: “0”,
“s02ldap_turn_on_pwd_change”: “0”,
“s02ldap_user_avatar_rule”: “default”,
“s02ldap_user_display_name_2”: “”,
“s02ldap_user_filter_mode”: “0”,
“s02ldap_userfilter_groups”: “Cloud Users”,
“s02ldap_userfilter_objectclass”: “”,
“s02ldap_userlist_filter”: “(|(|(memberof=CN=Cloud Users,CN=Users,DC=trautes,DC=heim)(primaryGroupID=1104)))”,
“s02use_memberof_to_detect_membership”: “1”,
“user_status”: {
“enabled”: “no”,
“installed_version”: “1.0.1”,
“types”: “”
“viewer”: {
“enabled”: “yes”,
“types”: “”
“weather_status”: {
“enabled”: “no”,
“installed_version”: “1.0.0”,
“types”: “”
“workflowengine”: {
“enabled”: “yes”,
“installed_version”: “2.8.0”,
Detailed Log
[no app in context] Warning: OCP\Files\StorageNotAvailableException: Storage with mount id 8 is not available at <>
- /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php line 545
OC\Files\Storage\FailedStorage->getAvailability() - /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php line 545
OC\Files\Storage\Wrapper\Wrapper->getAvailability() - /var/www/html/lib/private/Files/Storage/Wrapper/Availability.php line 81
OC\Files\Storage\Wrapper\Wrapper->getAvailability() - /var/www/html/lib/private/Files/Storage/Wrapper/Availability.php line 92
OC\Files\Storage\Wrapper\Availability->isAvailable() - /var/www/html/lib/private/Files/Storage/Wrapper/Availability.php line 342
OC\Files\Storage\Wrapper\Availability->checkAvailability() - /var/www/html/lib/private/legacy/OC_Helper.php line 525
OC\Files\Storage\Wrapper\Availability->free_space(“”) - /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php line 336
OC_Helper::getStorageInfo(“/scan”, [“OC\Files\Node\Folder”], false) - /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 770
OCA\DAV\Connector\Sabre\Directory->getQuotaInfo() - /var/www/html/3rdparty/sabre/dav/lib/DAV/PropFind.php line 95
Sabre\DAV\CorePlugin->Sabre\DAV{closure}(“*** sensitive parameters replaced ***”) - /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 768
Sabre\DAV\PropFind->handle(“{DAV:}quota-available-bytes”, [“Closure”]) - /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->propFind([“Sabre\DAV\PropFind”], [“OCA\DAV\Connector\Sabre\Directory”]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1052
Sabre\DAV\Server->emit(“propFind”, [["Sabre\DAV\P … ]]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 984
Sabre\DAV\Server->getPropertiesByNode([“Sabre\DAV\PropFind”], [“OCA\DAV\Connector\Sabre\Directory”]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1662
Sabre\DAV\Server->getPropertiesIteratorForPath(“files/61CD9C9C- … 8”, ["{DAV:}getlastm … "], 1) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1647
Sabre\DAV\Server->writeMultiStatus(["Sabre\Xml\Wr … ]], [“Generator”], false) - /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 346
Sabre\DAV\Server->generateMultiStatus([“Generator”], false) - /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPropFind([“Sabre\HTTP\Request”], [“Sabre\HTTP\Response”]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 472
Sabre\DAV\Server->emit(“method:PROPFIND”, [["Sabre\HTTP\ … ]]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod([“Sabre\HTTP\Request”], [“Sabre\HTTP\Response”]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start() - /var/www/html/apps/dav/lib/Server.php line 366
Sabre\DAV\Server->exec() - /var/www/html/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec() - /var/www/html/remote.php line 172
require_once(“/var/www/html/a … p”)
Caused by:
OCA\Files_External\Config\ConfigAdapter->OCA\Files_External\Config{closure}(“*** sensitive parameters replaced ***”) - /var/www/html/apps/files_external/lib/Config/ConfigAdapter.php line 137
array_map([“Closure”], ["*** sensitive … “], [”*** sensitive … "]) - /var/www/html/lib/private/Files/Config/MountProviderCollection.php line 89
OCA\Files_External\Config\ConfigAdapter->getMountsForUser([“OC\User\User”], [“OC\Files\Storage\StorageFactory”]) - /var/www/html/lib/private/Files/Config/MountProviderCollection.php line 138
OC\Files\Config\MountProviderCollection->getMountsFromProvider(["OCA\Files_Ext … "], [“OC\User\User”], [“OC\Files\Storage\StorageFactory”]) - /var/www/html/lib/private/Files/SetupManager.php line 224
OC\Files\Config\MountProviderCollection->addMountForUser([“OC\User\User”], [“OC\Files\Mount\Manager”], [“Closure”]) - /var/www/html/lib/private/Files/SetupManager.php line 327
OC\Files\SetupManager->OC\Files{closure}(“*** sensitive parameters replaced ***”) - /var/www/html/lib/private/Files/SetupManager.php line 223
OC\Files\SetupManager->setupForUserWith([“OC\User\User”], [“Closure”]) - /var/www/html/lib/private/Files/SetupManager.php line 406
OC\Files\SetupManager->setupForUser([“OC\User\User”]) - /var/www/html/lib/private/Files/Mount/Manager.php line 128
OC\Files\SetupManager->setupForPath(“/61CD9C9C-7D24- … s”, true) - /var/www/html/lib/private/Files/View.php line 1497
OC\Files\Mount\Manager->findIn(“/61CD9C9C-7D24- … s”) - /var/www/html/lib/private/Files/Node/Folder.php line 101
OC\Files\View->getDirectoryContent(“/61CD9C9C-7D24- … /”, “”, [“OC\Files\Node\LazyUserFolder”]) - /var/www/html/lib/private/Share20/DefaultShareProvider.php line 696
OC\Files\Node\Folder->getDirectoryListing() - /var/www/html/lib/private/Share20/Manager.php line 1310
OC\Share20\DefaultShareProvider->getSharesInFolder(“61CD9C9C-7D24-4A2E-AF32-958EAB554D18”, [“OC\Files\Node\Folder”], true, true) - <>
OC\Share20\Manager->OC\Share20{closure}(“*** sensitive parameters replaced ***”) - /var/www/html/lib/private/Share20/Manager.php line 1309
array_reduce(["*** sensitive … ]], [“Closure”], “*** sensitive parameters replaced ***”) - /var/www/html/apps/dav/lib/Connector/Sabre/SharesPlugin.php line 135
OC\Share20\Manager->getSharesInFolder(“61CD9C9C-7D24-4A2E-AF32-958EAB554D18”, [“OC\Files\Node\Folder”], true) - /var/www/html/apps/dav/lib/Connector/Sabre/SharesPlugin.php line 195
OCA\DAV\Connector\Sabre\SharesPlugin->getSharesFolder([“OC\Files\Node\Folder”]) - /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
OCA\DAV\Connector\Sabre\SharesPlugin->handleGetProperties([“Sabre\DAV\PropFind”], [“OCA\DAV\Files\FilesHome”]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1052
Sabre\DAV\Server->getPropertiesByNode([“Sabre\DAV\PropFind”], [“OCA\DAV\Files\FilesHome”]) - /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1662
Sabre\DAV\Server->writeMultiStatus(["Sabre\Xml\Wr … "], [“Generator”], false) - /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 346
PROPFIND /remote.php/dav/files/61CD9C9C-7D24-4A2E-AF32-958EAB554D18/
from 193.34.100.34 by 61CD9C9C-7D24-4A2E-AF32-958EAB554D18 at 2023-08-28T07:49:24+00:00
