i have a couple of rather strange things happening that i would like to understand.
Issue 1: I am using nextcloudpi version 16(updated to 17) and in both versions the light on the Ethernet port is constantly blinking(about every second or so). Is this normal ?
issue 2:
I wanted to use my nextcloudpi away from home as well as locally…and i am not sure how i did it but eventually got the no-ip thing to work…at least i think so as when i configured my router to port forward it didnt work…but using the ni-ip config seemed to do the job. Anyhow, the way i can use nextcloudpi away from home is: The android app, with no-ip login OR web based again with no-ip details. So basically i have the android app set to normal log in so i can use it on wifi and web based with no-ip login. Is this normal and if not what have i done wrong ?
Dont get me wrong…this in the scheme of things is no bad thing, just i would like to use the android app with on the wifi and mobile internet.
Brilliant software mind you and thanks to the team for everything ![]()
