Slim Application Error logging into AIO Interface
example
longer
example
here
Nextcloud version (eg, 29.0.5): 29.0.1.1
Operating system and version (eg, Ubuntu 29.04): Docker on Open Media Vault server
Apache or nginx version (eg, Apache 2.4.25): 2.4.59
PHP version (eg, 8.3): 8.2.18
When I try to log into the AIO Interface at port 8080, either by following the link from the admin settings, or directly entering the ip, or the DNS, I receive a “Slim Application Error” with no further details.
  1. Attempt to log in to AIO Interface
\\Connection","type":"->","args":["DELETE FROM \"oc_appconfig\" WHERE (\"appid\" = :dcValue1) AND (\"configkey\" = :dcValue2)",["core","cronErrors"],[2,2]]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":326,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":1106,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AllConfig.php","line":232,"function":"deleteKey","class":"OC\\AppConfig","type":"->","args":["core","cronErrors"]},{"file":"/var/www/html/lib/base.php","line":754,"function":"deleteAppValue","class":"OC\\AllConfig","type":"->","args":["core","cronErrors"]},{"file":"/var/www/html/lib/base.php","line":1181,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/cron.php","line":58,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/PgSQL/Driver.php","Line":34}}},"message":"An exception occurred in the driver: SQLSTATE[08006] [7] could not translate host name \"nextcloud-aio-database\" to address: Try again","exception":{},"CustomMessage":"An exception occurred in the driver: SQLSTATE[08006] [7] could not translate host name \"nextcloud-aio-database\" to address: Try again"}}
{"reqId":"x9N3C8PHzH9oLgf0CLVn","level":2,"time":"2024-07-02T20:35:42+00:00","remoteAddr":"154.47.25.18","user":"admin","app":"suspicious_login","method":"POST","url":"/login","message":"Could not predict suspiciousness: No models found","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:127.0) Gecko/20100101 Firefox/127.0","version":"29.0.1.1","data":{"app":"suspicious_login"}}
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'appsallowlist' => false,
  'check_data_directory_permissions' => false,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'REDACTED',
    'port' => 6379,
  'overwritehost' => 'REDACTED',
  'passwordsalt' => 'REDACTED',
  'secret' => 'REDACTED',
    0 => 'localhost',
    1 => 'REDACTED',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '29.0.1.1',
  'overwrite.cli.url' => 'REDACTED',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database',
  'dbuser' => 'oc_nextcloud',
  'dbpassword' => 'REDACTED',
  'default_phone_region' => 'US',
  'instanceid' => 'ocq9fnyg6m0u',
  'updatedirectory' => '/nc-updater',
  'loglevel' => '2',
  'app_install_overwrite' =>
    0 => 'nextcloud-aio',
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => '10485760',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => '2048',
  'preview_max_y' => '2048',
  'jpeg_quality' => '60',
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
    7 => 'OC\\Preview\\Krita',
    0 => 'OC\\Preview\\Imaginary',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => '30',
  'share_folder' => '/Shared',
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
  'maintenance_window_start' => 100,
  'allow_local_remote_servers' => true,
  'davstorage.request_timeout' => 3600,
  'dbpersistent' => false,
  'auth.bruteforce.protection.enabled' => true,
  'ratelimit.protection.enabled' => true,
  'files_external_allow_create_new_local' => true,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
    10 => '192.168.240.1/32',
  'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
  'preview_imaginary_key' => '6c76d2f7fb1d9e324bb1f3a2a5c7f190687b9c0ed80a4e52',
  'mail_from_address' => 'REDACTED',
  'mail_domain' => 'gmail.com',
  'mail_smtphost' => 'smtp.gmail.com',
  'mail_smtpport' => '465',
  'mail_smtpauth' => 1,
  'mail_smtpname' => 'REDACTED',
  'mail_smtppassword' => 'REDACTED ',
Waiting for Nextcloud to start...
Connection to nextcloud-aio-nextcloud (192.168.240.8) 9000 port [tcp/*] succeeded!
{"level":"info","ts":1719879427.381502,"msg":"using provided configuration","config_file":"/tmp/Caddyfile","config_adapter":""}
[Mon Jul 01 20:17:07.392603 2024] [mpm_event:notice] [pid 74:tid 139828886182664] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
[Mon Jul 01 20:17:07.392914 2024] [core:notice] [pid 74:tid 139828886182664] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1719952374.3786087,"msg":"using provided configuration","config_file":"/tmp/Caddyfile","config_adapter":""}
[Tue Jul 02 16:32:54.392722 2024] [mpm_event:notice] [pid 34:tid 140482142169864] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
[Tue Jul 02 16:32:54.393366 2024] [core:notice] [pid 34:tid 140482142169864] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
END OF LINE
{"reqId":"0fljylXUWqvwZIvgT03D","level":3,"time":"2024-05-27T20:40:36+00:00","remoteAddr":"","user":"admin","app":"PHP","method":"","url":"--","message":"fopen(/var/www/html/config/config.php): Failed to open stream: No such file or directory at /var/www/html/lib/private/Config.php#225","userAgent":"--","version":"28.0.5.1","data":{"app":"PHP"},"id":"668467ef91a5a"}
[PHP] Error: Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234
	GET /index.php/apps/notify_push/test/version
	from 74.215.23.9 by -- at May 27, 2024, 4:45:12 PM
[core] Error: Error while running background job OCA\Theming\Jobs\MigrateBackgroundImages (id: 60, arguments: {"stage":"prepare"})
	from ? by -- at May 27, 2024, 4:45:13 PM
[index] Error: Could not get appdata folder for theming
	GET /apps/theming/icon?v=b6589fc6
	from 149.88.105.225 by -- at May 27, 2024, 4:48:25 PM
Hi, can you post the output of sudo docker logs nextcloud-aio-mastercontainer here?
This is the first time I’ve ever used a pastebin, so bear with me.
It looks like your configuration.json is somehow broken: Nextcloud aio mastercontainer logs · GitHub
You can use the following command in order to open it with a text editor and try to fix the json syntax manually: sudo docker run -it --rm --volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config:rw alpine sh -c "apk add --no-cache nano && nano /mnt/docker-aio-config/data/configuration.json"
Granted I’m new to programming, but i can’t for the life of me find a syntax error in configuration.json. And the error log seems to be pointing to a piece of code that isn’t even in that file, since it has the number “512”-- which is what i’m trying to set the memory limit to. But that’s not in this file. And I can’t find the ConfigurationManager.php file mentioned in the error message.
There are json validators around. Make sure to not put any sensitive data into them…
The validation checks out (thank you, i didn’t know those validators existed).
Thank you for your help. I found a misplaced ". But then I’m so used to working in VS Code lately that I forgot to hit save before restarting the container. It fixed the problem when I did.
