Hey Guys,
i just try to setup a NC Instance primarily for Videochat via Talk for me and my peers, and blasted through the standard install like a pro, inclusive a Letsencrypt implementation for the first time,… Yay!
But when i noticed, that the videochat doesnt work out of the box, i discovered this thread:
so i need a TURN server. Fine,…
To My setup:
Ubuntu 18.04
Apache2
Mariadb10
php7.2
KVM vServer at edis. Since my Network Adapter shows my external IP adress i assume there is next to nothing between me and the internet. Meaning no NAT etc, all ports seem to be open by default (will install a firewall later).
Talk App
I tried to stick to the thread above followed the instructions here:
the coturn service is installed and running, set it to enabled and de-commented the following:
cat /etc/turnserver.conf | egrep -v "(^#.*|^$)"
listening-port=3478
fingerprint
lt-cred-mech
use-auth-secret
static-auth-secret=*********************
realm=nc.mydomain.com
total-quota=100
bps-capacity=0
stale-nonce
no-loopback-peers
no-multicast-peers
I tried both listening ports for TLS and nonTLS and stale-nonce was =600 before and edited it out for testing.
Is there something i overlooked, the howto is confusing me not knowing if there is something missing for TLS.
By the Way: From the outside port 3478
is reachable, whereas 5349
is not.
In the Settings page in my NC i filled Stun Server with nc.mydomain.com:5349 (not sure if this is needed or even breaks thing, didnt work before either)
Turn Server the same with the above secret in the secret filed and UDP and TCP turned on.
Now me and my friends testet this, we want to make group videocalls for “Stammtisch” reasons due to the Zombie Apocalypse. But some peple having a hard time getting the audio/video streaming to work. When my and my GF are in the same call both from inside our home network, we get very interesting phenomena, like 3rd call member seeing and hearing both of us, but me not seeing or hearing her.
Do i need a STUN and a TURN Server? TURN seems to work, but after further reading it seems, that a STUN Server needs its own IP, and this would just cost more money, so i want to avoid that. Is the pre filled out STUN server under “stun.nextcloud.com:443” an actual stun server i can use, or is this just a dummy?
I hope this is not confusing, since i started this post, when i had initail problems finding out i need TRUN, overcome them, and edited it after the test yesterday where the partial problems described occured.
Thanks in advance.
