Hi guys,
I’m using the official docker image with a slightly modified docker-compose file:
volumes:
nextcloud:
apps:
config:
db:
services:
db:
image: mariadb
container_name: nextcloud_db
restart: always
volumes:
- db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=redacted
- MYSQL_PASSWORD=redacted
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud
ports:
- 8050:80
links:
- db
volumes:
- nextcloud:/var/www/html
- apps:/var/www/html/custom_apps
- config:/var/www/html/config
- /mnt/raid/next-cloud/data:/var/www/html/data
restart: always
This is then proxied via nginx:
``server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
include /etc/nginx/ssl.conf;
server_name data.redacted.co.uk;
location / {
proxy_pass http://localhost:8050;
I’ve changed my config.php to have the following:
'memcache.local' => '\\OC\\wMemcache\\APCu',
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'redacted',
'passwordsalt' => 'redacted',
'secret' => `redacted',
0 => 'localhost:8050',
'version' => '15.0.0.10',
'overwrite.cli.url' => 'https://data.redacted.co.uk',
'dbname' => 'nextcloud',
'dbhost' => 'nextcloud_db:3306',
'dbuser' => 'nextcloud',
'dbpassword' => 'redacted',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
But all of the share links and WebDAV links are showing up as http://localhost:8050/... which is obviously incorrect. How do I change this?
