`setupchecks` CLI command various issues; takes long time, delayed output, no logs, etc
    • traefik:3.6.10 Community Docker build
    • Yes
    • Just about as of the time I’m posting this (today)
Very similar to this locked topic. The occ setupchecks command takes a long time (almost exactly 8 minutes: [7m 52.886s]) to execute. There is no CLI output until the very end, nor any logging output as far as I can see. It also can’t be interrupted (Ctrl+C) (not sure if possible to work around/fault of docker interface?) During this time, a php process consumes the maximum amount of CPU available, but at least in a respectful way that still allows everything including the nextcloud server to continue responding to requests.
Is there any way for me to get a closer look inside of setupchecks while it’s running? Thank you all in advance.
  1. Run php occ -vvv setupchecks (in my case, docker exec -it nextcloud php occ -vvv setupchecks)
  2. Observe as command takes 8 minutes to complete, not outputing any information by internal logging system, Docker logging system or CLI. CLI & web output only available after all work appears to be done.
No log entries related to the setupchecks process appear to be generated.
Does affect the Overview portion of the web interface, too. Would there be any local web console output if the CLI or logging interface aren’t generating anything?
The apache2 error log is linked to the /dev/stderror device, and I’m not sure where that’s going. The docker logs for this container only appear to show access from web.
            "***Host on private subdomain directed by AdGuardHome container***"
        "overwriteprotocol": "https",
        "overwrite.cli.url": "***Host on private subdomain directed by AdGuardHome container***",
        "htaccess.RewriteBase": "\/",
        "dbtype": "pgsql",
        "version": "32.0.9.2",
        "maintenance_window_start": 7,
        "upgrade.disable-web": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "loglevel": 1,
        "forbidden_filename_basenames": [
            "con",
            "prn",
            "aux",
            "nul",
            "com0",
            "com1",
            "com2",
            "com3",
            "com4",
            "com5",
            "com6",
            "com7",
            "com8",
            "com9",
            "com\u00b9",
            "com\u00b2",
            "com\u00b3",
            "lpt0",
            "lpt1",
            "lpt2",
            "lpt3",
            "lpt4",
            "lpt5",
            "lpt6",
            "lpt7",
            "lpt8",
            "lpt9",
            "lpt\u00b9",
            "lpt\u00b2",
            "lpt\u00b3"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
        "app_install_overwrite": [],
        "redis": {
            "host": "redis", (On private docker network. redis output seems to confirm successful access)
            "port": "6379"
  - activity: 5.0.0
  - admin_audit: 1.22.0
  - app_api: 32.0.0
  - calendar: 6.4.2
  - contacts: 8.3.11
  - contactsinteraction: 1.13.1
  - cookbook: 0.11.6
  - dashboard: 7.12.0
  - dav: 1.34.2
  - deck: 1.16.5
  - files: 2.4.0
  - files_downloadlimit: 5.0.0
  - files_pdfviewer: 5.0.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0
  - integration_google: 4.3.1
  - logreader: 5.0.0
  - nextcloud_announcements: 4.0.0
  - notifications: 5.0.0
  - oauth2: 1.20.0
  - password_policy: 4.0.0
  - photos: 5.0.0
  - privacy: 4.0.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - recommendations: 5.0.0
  - related_resources: 3.0.0
  - serverinfo: 4.0.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - support: 4.0.0
  - survey_client: 4.0.0
  - systemtags: 1.22.0
  - tasks: 0.17.1
  - text: 6.0.2
  - theming: 2.7.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - bruteforcesettings: 5.0.0 (installed 2.4.0)
  - circles: 32.0.0 (installed 24.0.0)
  - comments: 1.22.0 (installed 1.14.0)
  - encryption: 2.20.0
  - federation: 1.22.0 (installed 1.18.0)
  - files_external: 1.24.1
  - suspicious_login: 10.0.0
  - twofactor_nextcloud_notification: 6.0.0
  - twofactor_totp: 14.0.0
  - user_ldap: 1.23.0
  - weather_status: 1.12.0 (installed 1.8.0)
