- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
31.0.13.1
- Red Hat Enterprise Linux release 9.7 (Plow)
- nginx/1.20.1
replace me
- PHP version (e.g, 8.3):
- PHP 8.3.30
Yes
When upgrading to 30.0.2
Archive
No
settings/admin/overview shows
Could not check that the data directory is protected. Please check manually that your server does not allow access to the data directory. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its `trusted_domains` or the `overwrite.cli.url`. This failure may be the result of a server-side DNS mismatch or outbound firewall rule.
sudo -u apache php occ setupchecks -vvv
shows✗ WebDAV endpoint: Your web server is not yet properly set up to allow file synchronization, because the WebDAV interface seems to be broken.
To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of itstrusted_domainsor theoverwrite.cli.url. This failure may be the result of a server-side DNS mismatch or outbound firewall rule. -
Log shows, that HTTP connections are tried. But only HTTPS is configured. Port 80 is closed.
Steps to replicate it (hint: details matter!)
Upgrade to 30.0.2
PASTE HERE "reqId": "A5T5ZSxqm7qR1rokylnn",
"level": 0,
"time": "January 22, 2026 11:58:22",
"remoteAddr": "",
"user": "--",
"app": "settings",
"method": "",
"url": "--",
"scriptName": "occ",
"message": "Can not connect to local server for running setup checks",
"userAgent": "--",
"version": "31.0.13.1",
"occ_command": [
"occ",
"setupchecks"
"exception": {
"Exception": "GuzzleHttp\\Exception\\ConnectException",
"Message": "cURL error 28: Operation timed out after 30001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for
http://a.b.c/apps/theming/fonts/OpenDyslexic-Regular.otf",
"Code": 0,
"Trace": [
"file": "/var/www/abc/nextcloud-31.0.13/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php",
"line": 205,
"function": "createRejection",
"class": "GuzzleHttp\\Handler\\CurlFactory",
"type": "::",
"args": [
"*** sensitive parameters replaced ***"
"line": 157,
"function": "finishError",
"type": "::"
PASTE
PASTE HERE
0 => 'a.b.c',
'datadirectory' => '/var/www/abc/data',
'version' => '31.0.13.1',
'overwrite.cli.url' => 'https://a.b.c',
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
