Settings dialog will not open on Nextcloud Desktop
example
longer
example
here
Nextcloud desktop version:
$ nextcloud --version
Nextcloud version 3.10.0-20230916.115628.ad2cf1b57-1.0~jammy1
Using Qt 5.15.3, built against Qt 5.15.3
Using Qt platform plugin 'xcb'
Using 'OpenSSL 3.0.2 15 Mar 2022'
Running on Linux Mint 21.1, x86_64
Installed from the PPA
One on linux machine I am unable to open the Settings dialog for the desktop client. I can do this neither through right-clicking the tray icon and choosing settings, nor through the main window menu. When I try either way, simply nothing happens.
In case it is relevant, I recently upgraded this machine from Mint Linux 20.3, using the Mint upgrade tool to upgrade in place.
Can anyone help? I have another machine with the following versions which works fine:
Nextcloud version 3.9.4-20230908.164710.c8fec0118-1.0~jammy1
Running on Linux Mint 21.2, x86_64
