Caddy Reverse Proxy Issue with Nextcloud All-in-One
1. The Problem I’m Having
I am trying to set up Caddy as a reverse proxy for Nextcloud All-in-One (AIO). However, I am encountering a “connection refused” error.
- I can access the Nextcloud AIO container directly via my server’s IP and port. From which I was able to download other nextcloud containers.
- Other services are successfully proxied through Caddy without issues.
- The problem seems to be specific to proxying the Nextcloud AIO container.
2. Error Messages and Full Log Output
Here is the error log from Caddy:
{"level":"debug","ts":1740318299.1760828,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"146.70.99.219","remote_port":"37363","subjects":["ncaio.datanotch.website"],"managed":true,"expiration":1747857216,"hash":"598237a32531d1c14f19a557e0dc70969d06d58d1e1f3851d4343257080e8941"}
{"level":"debug","ts":1740318299.4637141,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"nextcloud-aio-mastercontainer:11000","total_upstreams":1}
{"level":"debug","ts":1740318299.466965,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"nextcloud-aio-mastercontainer:11000","duration":0.002803152,"request":{"remote_ip":"146.70.99.219","remote_port":"37363","client_ip":"146.70.99.219","proto":"HTTP/2.0","method":"GET","host":"ncaio.datanotch.website","uri":"/","headers":{"Cache-Control":["max-age=0"],"Sec-Fetch-Site":["cross-site"],"Sec-Ch-Ua":["\"Not(A:Brand\";v=\"99\", \"Brave\";v=\"133\", \"Chromium\";v=\"133\""],"X-Forwarded-Host":["ncaio.datanotch.website"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"X-Forwarded-For":["146.70.99.219"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Priority":["u=0, i"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua-Mobile":["?0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"],"Sec-Gpc":["1"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"ncaio.datanotch.website"}},"error":"dial tcp 172.21.0.3:11000: connect: connection refused"}
{"level":"error","ts":1740318299.467332,"logger":"http.log.error","msg":"dial tcp 172.21.0.3:11000: connect: connection refused","request":{"remote_ip":"146.70.99.219","remote_port":"37363","client_ip":"146.70.99.219","proto":"HTTP/2.0","method":"GET","host":"ncaio.datanotch.website","uri":"/","headers":{"Sec-Fetch-Site":["cross-site"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Gpc":["1"],"Sec-Fetch-User":["?1"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Dest":["document"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\"Not(A:Brand\";v=\"99\", \"Brave\";v=\"133\", \"Chromium\";v=\"133\""],"Accept-Encoding":["gzip, deflate, br, zstd"],"Priority":["u=0, i"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"ncaio.xxxxxx.xxxxxx"}},"duration":0.003587865,"status":502,"err_id":"uyij28cys","err_trace":"reverseproxy.statusError (reverseproxy.go:1373)"}
Caddy Version
I am running Caddy v2.9.1 (v2.9.1 h1:OEYiZ7DbCzAWVb6TNEkjRcSCRGHVoZsJinoDR/n9oaY=).
How I Installed and Ran Caddy
###Dockerfile for Custom Caddy Image
FROM caddy:builder AS builder
RUN xcaddy build \
--with github.com/lucaslorentz/caddy-docker-proxy/v2 \
--with github.com/caddy-dns/cloudflare
FROM caddy:alpine
COPY --from=builder /usr/bin/caddy /usr/bin/caddy
CMD ["caddy", "docker-proxy"]
Docker Compose for Caddy
services:
caddy:
image: caddy-image:1 # Custom Caddy image
container_name: caddy
restart: unless-stopped
ports:
- "80:80"
- "443:443"
volumes:
- ./Caddyfile:/etc/caddy/Caddyfile # Optional: Static Caddyfile
- ./certs:/certs # Volume for certificates
- ./config:/config # Volume for Caddy configuration
- ./data:/data # Volume for Caddy data
- ./sites:/srv # Volume for serving static files
- /var/run/docker.sock:/var/run/docker.sock:ro # Required for caddy-docker-proxy
environment:
- CADDY_DOCKER_PROXY_NETWORK=caddy_network # Specify the network for caddy-docker-proxy
networks:
- caddy_network
networks:
caddy_network:
driver: bridge
external: true
Docker Compose for Nextcloud AIO
services:
nextcloud:
ports:
- "8081:8080"
environment:
- APACHE_PORT=11000
- APACHE_IP_BINDING=0.0.0.0
- SKIP_DOMAIN_VALIDATION=false
- NEXTCLOUD_UPLOAD_LIMIT=20G
- NEXTCLOUD_MAX_TIME=3000
- NEXTCLOUD_MEMORY_LIMIT=2024M
- TALK_PORT=3478
volumes:
networks:
- caddy_network
networks:
caddy_network:
external: true
volumes:
Complete Caddy Configuration
Here is my Caddyfile:
debug
email xxxxxxxxxxxxxxxxxxx
acme_ca https://acme-v02.api.letsencrypt.org/directory
acme_dns cloudflare xxxxxxxxxxxxxxxxxxxxxxxxx
default_sni xxxxxx.com
*.xxxxx.com {
tls {
https://caddy.xxxxx.com:443 {
respond "Hello, world!"
https://upk.xxxxx.com:443 {
reverse_proxy uptime-kuma:3001
https://ncaio.xxxxx.com:443 {
reverse_proxy nextcloud-aio-mastercontainer:11000
ADDITIONAL INFORMATIONS
The error dial tcp 172.21.0.3:11000: connect: connection refused suggests that Caddy cannot reach the Nextcloud AIO container at nextcloud-aio-mastercontainer:11000. I have modified my Caddyfile for nextcloud-aio block as this :
https://ncaio.xxxxxx.xxxx:443 {
reverse_proxy nextcloud-aio-apache:11000
and
https://ncaio.xxxxxxx:443 {
reverse_proxy nextcloud-aio-mastercontainer:8081
and
https://ncaio.xxxxxxxx.:443 {
reverse_proxy nextcloud-aio-apache:8081
Neither worked, I either got a timeout error or connection refused error
