Hi.
Im quite new at this, so im hoping for some help here.
I have Nextcloud docker container running on my unraid server with mariadb.
Local access works fine, but i would like to have remote access aswell.
I want to use my asus GT-AC5300 router for DDNS. It is setup as follows:
Method to retrieve WAN IP - External
Host Name - xxxxxxx.asuscomm.com
DDNS Status - Active
HTTPS/SSL Certificate - Free Certificate from Let’s Encrypt
Port forwarding:
Internal IP Address - 192.168.1.1XX Port 443,80,8080.
Protocol - TCP
Port mapping in unraid docker
Nextcloud - 172.17.0.X:443/TCP – 192.168.1.1XX:444
(I have tried to use the other ip in my setup, and its not working)
Nextcloud config file -
0 => '192.168.1.xxx:444',
1 => 'xxxxxxxxx.asuscomm.com:443',
Im getting “Malformed server configuration” when trying to connect.
Any help would be greatly appreciated.
