Setting up AI and Assistant
I’m trying to setup an instance with a localai using Ollama but I’m not able to get results and I’m not sure how to identify what I’m missing. I seem to have all neccessary apps installed. I’m running Ollama on a local server that is accessible within the internal network of my self-hosted Nextcloud server. If I run queries off the server directly or through the OpenWebUI everything is great. Nextcloud is picking up the all of my models from the URL so I’m pretty sure it is talking. But I cannot get any results to return from the Assistant. Anyone know of some steps I may have missed or how to seek where the failure is taking place? It doesn’t even seem to timeout or provide any error messages for me… just keeps spinning…
Maybe you are missing the worker service!?
Yep. I’m 99% sure this is the case, since models seem to load, but the response just takes a veeeery long time since Nextcloud will queue them up, and not run directly.
I have 6 workers set up, also use Ollama ( with llama 3.2 ), and the response is usually almost instantly, unless it has to return a very long file/code, then it takes around a max. of 7 seconds to complete.
After you’ve followed the steps to create your workers, you could use a script like this to start them up (6 workers in this specific case):
#!/bin/bash
# Log file for errors and status
log_file="/var/log/nextcloud_workers.log"
# Start all workers
for i in {1..6}; do
    echo "Starting nextcloud-ai-worker@$i.service" | tee -a $log_file
    sudo systemctl start nextcloud-ai-worker@$i.service 2>> $log_file
    if systemctl is-active --quiet nextcloud-ai-worker@$i.service; then
        echo "nextcloud-ai-worker@$i.service started successfully." | tee -a $log_file
    else
        echo "Failed to start nextcloud-ai-worker@$i.service. Check logs for details." | tee -a $log_file
    fi
done
Good luck and get that Nextcloud Assistant runnning :slight_smile:
you Ollama end point should be this http://abc.com:11434/v1,this will pick up all the models.
I am using Ollama with OpenWebUI .It is very efficient .Willing to help
Yes, I have the models all showing up. But nothing works past that. I assume the workers have to be set up manually as others mention?
I did not set up any workers ,which app are you using to connect with backend
I’m just trying the Assistant.
Download openwebAI and Local AI app ,punch in the info there it will take care of worker set up etc
AFAIK, you have to set up the workers manually. there is no automatic setup. If you don’t do this, prepare to wait a couple minutes each time you prompt the AI for something, which I’m pretty sure is not what you want.
I trust you ,however I haven no issues till date .Are threre any documentation related to workflow.Will give it a try
Did you read up the documentation? yes, you won’t have any issues. Just major delays if you ask the AI something. I’m pretty sure you’re not receiving answers within 10 seconds if you haven’t set up any workers.
Take the time and read the official documentation regarding workers.
Yes to all that said the workers needed to be added… I did the work (was easier than I thought) and voila! works like magic! Excited to see what all we can do now! Thanks all around!
@mcoulter @M_M1 you are right workers needs to be added but how do i add a worker and how many needs to be added .This link gives an example Overview — Nextcloud latest Administration Manual latest documentation but not sure how to go about it.Can you please help
For me, I followed step by step as written. I didn’t add and more workers. It worked well enough for now. I guess that includes 4 workers as written?
@M_M1 @mcoulter you are right workers have to be set ,but not able to figure out how to go about it .How many of them have to be set up .Here is the working example Overview — Nextcloud latest Administration Manual latest documentation is it only one worker which needs to be set up or plenty ,bit blind.I did go through the documentation but was not able to understand
yes just configured it it is quiet fast
Thanks @mcoulter @M_M1
