Setting quota is not respected, gets reset after logging in (S3 storage)
  • Nextcloud Server version:
    • 31.0.4
    • NixOS 24.11
  • Is this the first time you’ve seen this error?
    • When I switched to s3 storage
  • Installation method
    • nixpkgs module
Steps to reproduce
  • Change quota
  • Log out
  • Log in
  • Quota is back to the old value
Is there any way around this? I don’t really get the quick and dirty fix that is described in the posts I linked above, maybe I’ll try it if I get it. Is there some other way to try to deal with this problem? Maybe reset something? Otherwise I will also try to go away from S3.
it turned out to actually be a problem with a plugin oidc_login, where if you set a default quota, you apparently cannot change the quota within the webinterface, but only through the oidc user attribute quota. i had removed in config.php whatever enabled this behaviour but it didn’t stop, i was able to manually disable it by setting oidc_login_default_quota to 0 in config.php, which actively disables the feature. then it worked again. i wonder where this value was saved in the database, because if it is not set in config.php, it must be set as a value somewhere else.
it seems like it had nothing to do with s3, i was just influenced by other github issues
