Nextcloud version 10.0.6.1.
Hello. I’m very new here. Tried to find the answer to my question here and via google. No success. I would appreciate your support.
I have installed nextcloud via snap on my freshly installed ubuntu. As the default datadirectory I would like to use from scratch /EXTERNAL_DRIVE instead of /var/snap/nextcloud/common/nextcloud/data.
I am following the usual steps:
- sudo snap install nextcloud (no config.php in /var/snap/nextcloud/current/config/config.php so far)
- creating admin user + password (http://localhost/) --> config.php now available, however already with the default datadirectory value. Also the sample files have already been created in the default folder.
I understand, setting the datadirectory at this point to /EXTERNAL_DRIVE is already too late. But when and how can I properly set the desired value for datadirectory then?
Thanks and best regards.
