Set up a PIN code for passwordless authentication (since NC 30/Hub 9)
Fortsetzung der Diskussion von Be connected with Nextcloud Hub 9:
I was searching in every corner of user and admin settings for this. Where (the hell) is the option/setting to use this?!?
I think you refer to the security key PIN. it’s not related to NC itself - all FIDO2 security key support a PIN to access keys - in Windows 10 you can set/change the key in Win Hello options
Ah OK, if that’s what the release notes refer to, then it makes sense.
