Send invitations to attendees can not be activated
    • 34.0.2.1
    • Ubuntu 26.04
    • nginx 1.28.3-2ubuntu1.8
    • traefik 3.7.8
    • 8.5
    • yes
    • ? but before updating to 34.0.2.1 (was 33.0.7)
    • Bare Metal
    • no
Once Invitations was sent to the attendees but suddenly they are not sent to the attendees of calendar events. The Calendar server->Send invitations to attendees stays disabled, even if set to enabled. If you refresh the Calendar server page it is shown disabled again.
Because of the warnings in the nextcloud.log (see below) I tried to set the dav/sendInvitations attribute with occ command as type string (=“true”) and boolean(=true) with no luck, even after restarting redis, php, nginx.
  1. Setup system mails and test if mails are send
  2. in the admin section of calendar server set the attribute “Send invitations to attendees” to “on”.
  3. refresh the calendar server admin page. The attribute shows “off” again.
{"reqId":"WxaBoHSZmmwwS2Fj2zx6","level":1,"time":"2026-08-06T11:47:21+00:00","remoteAddr":"192.168.3.202","user":"user","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/user/","scriptName":"/remote.php","message":"The app config key dav/enableCalendarFederation is not defined in the config lexicon","userAgent":"Mozilla/5.0 (Macintosh) mirall/34.0.1 (Nextcloud, macos-25.5.0 ClientArchitecture: arm64 OsArchitecture: arm64)","version":"34.0.2.1","clientReqId":"74a81230-a803-448f-9388-9effe478f5e4","data":[]}
{"reqId":"WxaBoHSZmmwwS2Fj2zx6","level":1,"time":"2026-08-06T11:47:21+00:00","remoteAddr":"192.168.3.202","user":"bubi","user":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/user/","scriptName":"/remote.php","message":"The app config key dav/sendInvitations is not defined in the config lexicon","userAgent":"Mozilla/5.0 (Macintosh) mirall/34.0.1 (Nextcloud, macos-25.5.0 ClientArchitecture: arm64 OsArchitecture: arm64)","version":"34.0.2.1","clientReqId":"74a81230-a803-448f-9388-9effe478f5e4","data":[]}
ERROR] viewer: Could not register handler
Object { app: "viewer", uid: "user", level: 1, error: "The handler is already registered", handler: {…} }
index.mjs:47:17
    log index.mjs:47
    error index.mjs:65
    registerHandler Viewer.js:89
    beforeMount Viewer.vue:526
    beforeMount Viewer.vue:525
    (Async: EventListener.handleEvent)
    beforeMount Viewer.vue:522
    VueJS 16
    <anonym> main.js:32
        "overwriteprotocol": "https",
            "cloud.example.org"
        "dbtype": "mysql",
        "version": "34.0.2.1",
        "overwrite.cli.url": "https:\/\/cloud.example.org",
        "dbport": "",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": true,
        "mail_smtpport": "25",
        "theme": "",
        "mysql.utf8mb4": true,
        "app_install_overwrite": {
            "0": "files_ebookreader",
            "1": "impersonatte",
            "4": "epubreader",
            "5": "cookbook",
            "6": "apporder",
            "7": "facerecognition",
            "8": "passwords",
            "9": "pride",
            "10": "camerarawpreviews",
            "12": "music",
            "13": "radio",
            "14": "event_update_notification",
            "15": "richdocumentscode",
            "16": "maps",
            "17": "oidc",
            "18": "workflow_media_converter",
            "19": "fulltextsearch_elasticsearch",
            "20": "fulltextsearch",
            "21": "files_fulltextsearch",
            "22": "memories",
            "23": "side_menu"
        "enable_previews": true,
        "enabledPreviewProviders": [
            "OC\\Preview\\Image",
            "OC\\Preview\\Movie",
            "OC\\Preview\\TXT",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\OpenDocument",
            "OC\\Preview\\Krita",
            "OC\\Preview\\PDF"
        "default_phone_region": "DE",
        "loglevel": 1,
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "timeout": 0
        "memories.exiftool": "\/var\/www\/cloud.example.com\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/cloud.example.com\/apps\/memories\/bin-ext\/go-vod-amd64",
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "memories.vod.disable": false,
        "memories.gis_type": 1,
        "config_preset": 2,
        "enable_lazy_objects": false,
        "defaultapp": "dashboard,memories,files",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": false,
                "verify_peer": true,
                "verify_peer_name": true
        "dav\/sendInvitations": "true",
        "updater.secret": "***REMOVED SENSITIVE VALUE***"
  - activity: 7.0.0
  - admin_audit: 1.24.0
  - analytics: 6.7.1
  - announcementbanner: 2.4.3
  - announcementcenter: 7.4.1
  - app_api: 34.0.0
  - appstore: 1.0.0
  - assistant: 3.5.0
  - audiocoverpreview: 0.12.1
  - bruteforcesettings: 7.0.0
  - calendar: 6.5.2
  - calendar_resource_management: 0.12.1
  - camerarawpreviews: 1.1.2
  - circles: 34.0.0
  - cloud_federation_api: 1.18.0
  - collectives: 4.4.2
  - comments: 1.24.0
  - contacts: 8.7.5
  - contactsinteraction: 1.15.0
  - cookbook: 0.11.9
  - cospend: 4.0.2
  - dashboard: 7.14.0
  - dav: 1.39.0
  - eidlogin: 1.0.22
  - event_update_notification: 2.9.0
  - external: 9.0.1
  - federatedfilesharing: 1.24.0
  - federation: 1.24.0
  - files: 2.6.0
  - files_accesscontrol: 5.0.0
  - files_automatedtagging: 5.0.0
  - files_external: 1.26.0
  - files_fulltextsearch: 34.0.0
  - files_lock: 34.0.1
  - files_pdfviewer: 7.0.0-dev.0
  - files_reminders: 1.7.0
  - files_sharing: 1.26.0
  - files_trashbin: 1.24.0
  - files_versions: 1.27.0
  - fileslibreofficeedit: 2.0.1
  - firstrunwizard: 7.0.0-dev.0
  - forms: 5.3.5
  - fulltextsearch: 34.0.0
  - fulltextsearch_elasticsearch: 34.0.0
  - gestion: 3.2.5
  - gpxpod: 8.3.0
  - groupfolders: 22.0.6
  - guests: 4.9.0
  - impersonate: 5.0.0
  - integration_mattermost: 3.2.0
  - integration_openstreetmap: 4.2.0
  - logreader: 7.0.0
  - lookup_server_connector: 1.22.0
  - mail: 5.10.11
  - memories: 8.1.0
  - music: 3.1.1
  - nextcloud_announcements: 6.0.0
  - notes: 6.0.1
  - notifications: 7.0.0-dev.1
  - oauth2: 1.22.0
  - office: 1.0.0
  - pantry: 0.24.0
  - password_policy: 6.0.0-dev.0
  - passwords: 2026.7.20
  - phonetrack: 1.3.2
  - photos: 7.0.0
  - previewgenerator: 5.14.0
  - privacy: 6.0.0-dev.1
  - profile: 1.3.0
  - provisioning_api: 1.24.0
  - recognize: 12.0.0
  - recommendations: 7.0.0
  - registration: 3.0.0
  - related_resources: 5.0.0-dev.0
  - richdocuments: 11.1.0
  - richdocumentscode: 26.4.104
  - serverinfo: 6.0.0
  - settings: 1.17.0
  - sharebymail: 1.24.0
  - side_menu: 6.0.1
  - spreed: 24.0.3
  - survey_client: 6.0.0-dev.0
  - systemtags: 1.24.0
  - tables: 2.2.1
  - tasks: 0.18.1
  - text: 8.0.0
  - theming: 2.9.0
  - twofactor_backupcodes: 1.23.0
  - twofactor_nextcloud_notification: 8.0.0
  - twofactor_totp: 16.0.0
  - updatenotification: 1.24.0
  - user_status: 1.14.0
  - viewer: 7.0.0-dev.0
  - weather_status: 1.14.0
  - webhook_listeners: 1.6.0
  - whiteboard: 1.5.9
  - workflowengine: 2.16.0
  - context_chat: 5.4.0 (installed 5.4.0)
  - deck: 1.17.4 (installed 1.17.4)
  - encryption: 2.22.0 (installed 2.13.0)
  - epubreader: 1.4.7 (installed 1.4.7)
  - facerecognition: 0.9.70 (installed 0.9.70)
  - files_antivirus: 6.3.2 (installed 6.3.2)
  - files_bpm: 1.8.3 (installed 1.8.3)
  - files_downloadlimit: 5.2.0 (installed 2.0.0)
  - integration_github: 3.2.6 (installed 3.2.6)
  - integration_gitlab: 5.0.0 (installed 5.0.0)
  - integration_mastodon: 5.2.0 (installed 5.2.0)
  - integration_onedrive: 3.5.2 (installed 3.5.2)
  - integration_reddit: 2.3.0 (installed 2.3.0)
  - maps: 1.7.1 (installed 1.7.1)
  - notify_push: 1.3.5 (installed 1.3.5)
  - oidc: 2.0.4 (installed 2.0.4)
  - pto: 1.1.0 (installed 1.1.0)
  - quota_warning: 1.24.0 (installed 1.24.0)
  - radio: 1.0.3 (installed 1.0.3)
  - sip_trip_phone: 1.2.0 (installed 1.2.0)
  - stt_helper: 1.1.1 (installed 1.1.1)
  - stt_whisper: 1.0.8 (installed 1.0.8)
  - support: 6.0.0 (installed 1.12.0)
  - suspicious_login: 12.0.0-dev.0 (installed 4.4.0)
  - testing: 1.23.0
  - translate: 2.2.0 (installed 2.2.0)
  - twofactor_webauthn: 2.7.0 (installed 2.7.0)
  - user_ldap: 1.25.0
