Security scanner seems not to work
example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.4
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.46
PHP version (eg, 7.4): 7.4.16
The issue you are facing: scan.nextcloud.com shows me the old version of my instance, even after retrigger
Is this the first time you’ve seen this error? (Y/N):Y
  1. connect to scan.nextcloud.com
  2. Enter my URL
  3. Click trigger re-scan
  4. wait at least 5 Minutes
    It shows Version 21.0.3, tried even several times
The output of your Nextcloud log in Admin > Logging:No output in LOG
PASTE HERE
<?php $CONFIG = array ( 'instanceid' => 'XXX', 'passwordsalt' => 'XXX', 'secret' => 'XXX', 'trusted_domains' => array ( 0 => 'glinithai.ddns.net', ), 'memcache.local' => '\\OC\\Memcache\\APCu', 0 => array ( 'host' => 'localhost', 'port' => 6379, ), 'datadirectory' => '/srv/dateien/nextcloud/data', 'overwrite.cli.url' => 'https://glinithai.ddns.net/nextcloud', 'dbtype' => 'mysql', 'version' => '21.0.4.1', 'dbname' => 'nextcloud', 'dbhost' => 'localhost', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'nextcloud', 'dbpassword' => 'XXX', 'logtimezone' => 'UTC', 'installed' => true, 'maintenance' => false, 'mail_from_address' => 'carlo', 'mail_smtpmode' => 'sendmail', 'mail_domain' => 'glini.net', 'mail_smtphost' => 'smtp.glini.net', 'theme' => '', 'defaultapp' => 'spreed', 'loglevel' => 2, 'data-fingerprint' => 'd56160fd802481e31384c5f12bcd8494', 'mail_smtpport' => '465', 'mail_smtpauthtype' => 'LOGIN', 'mail_smtpsecure' => 'ssl', 'mysql.utf8mb4' => true, 'has_rebuilt_cache' => true, 'default_phone_region' => 'TH', 'app_install_overwrite' => array ( 0 => 'apporder', 1 => 'health', ), 'updater.release.channel' => 'stable', 'encryption.legacy_format_support' => false, 'encryption.key_storage_migrated' => false, ); ``` The output of your Apache/nginx/system log in `/var/log/____`: ``` PASTE HERE ```
I think the scanner does not really scan. The scanner reads e.g. “status.php” and perhaps some other public files (html, css, php).
You can find your nextcloud version from the internet with “status.php”.
https://cloud.server.tld/status.php
Does the scanner show the same version?
status.php on my instance give following output:
{“installed”:true,“maintenance”:false,“needsDbUpgrade”:false,“version”:“21.0.4.1”,“versionstring”:“21.0.4”,“edition”:"",“productname”:“Nextcloud”,“extendedSupport”:false}
so, this is the correect version
it looks security scanner is not really reliable at the moment:
Thank you for this information, but my problem is different.
msedge_2021-08-20_09-49-20
as one can see it reports an old scan date and status.php from my site reports
{"installed":true,"maintenance":false,"needsDbUpgrade":false,"version":"21.0.4.1","versionstring":"21.0.4","edition":"","productname":"Nextcloud","extendedSupport":false}
Did you click on “trigger re-scan” and check again a few minutes later? You probably have to reload the page after you triggered the re-scan.
several times
Hmm just tested it with my instance. It worked, expect for the known issue, that it does not recognise version 21.1.0.
Maybe to obvious as a question… But your Nextcloud is publicly accessible from the Internet via port 443? Apart from that, unfortunately, I can’t think of anything else right now…
yes, it is publicly accessible.
In fact I’m using this instance already a long time, and it’s a normal routine after update, to use the scanner. It always worked fine. But to be honest, actually it is not a big issue, hopefully it works again after next upgrade :wink:
I did new scan with two NC 21 yesterday (re-trigger scan) and another new scan today after I updated one of them to NC 22… my results update pretty fast and show right versions.
dumb question: do you have some caching mechanism in your browser or network (proxy)?
That was it, I don’t know what exactly, I have no proxy, but maybe something in Browser which I don’t know. I used the same Browser at least the last 2 or 3 time when I scanned the system and it worked fine.
But to be sure I went to another system and other Browser too, scanned and hey, it worked :grinning:
Good to know when something similar happens :wink:
thank you
