The second RC of Nextcloud 35 is now available on download servers! ![]()
If you notice anything out of order, please report back on the appropriate GitHub repository! ![]()
We will follow up with frequent RCs over the next weeks.
Downloads
Changelog
Nextcloud 35.0.0rc2
server
- Chore: update nextcloud-vue and nextcloud-dialogs (server#63568)
- Fix(dav): scope contact photo export to local address books (server#63646)
- Feat(Sharing): Implement API kill switch (server#63650)
- Fix(core): don’t hijack Ctrl+F in editors or behind modals (server#63653)
- Fix(core): let landed search results outgrow the reserved height (server#63659)
- Fix(dav): correctly mask public v1 links for non-home storages (server#63669)
- Fix(Sharing): Fix migration using wrong table names (server#63673)
- Ci(action): Don’t block merges during first and second RC of major re… (server#63675)
- Fix(dav): only derive the write size from a PUT Content-Length (server#63679)
- Chore(deps): Update openapi-extractor to v1.9.0 (server#63683)
- Feat(Sharing): Add user status for shares (server#63684)
- Feat(Updater): Ignore incompatible apps if the channel is git (server#63685)
- Fix(settings): Fix AI regex (server#63690)
- 35.0.0 RC2 (server#63702)
- Fix(contactsmenu): restore avatars for non-user contacts (server#63713)
activity
- Fix(CurrentUser): Properly get share token from non-legacy public webdav (activity#2877)
- Chore(CI): Adjust testing matrix for Nextcloud 35 on stable35 (activity#2881)
app_api
bruteforcesettings
circles
- Chore(CI): Adjust testing matrix for Nextcloud 35 on stable35 (circles#2810)
- Add “New Deck board” shortcut (circles#2825)
files_downloadlimit
files_lock
files_pdfviewer
firstrunwizard
- Fix: use proper AppStore route (firstrunwizard#2212)
- Chore(branchoff): Set version on stable35 to a stable one (firstrunwizard#2214)
logreader
- Chore(CI): Adjust testing matrix for Nextcloud 35 on stable35 (logreader#2202)
- Chore(deps): bump pinia from 4.0.2 to 4.0.3 (logreader#2205)
nextcloud_announcements
notifications
- Chore(branchoff): Set version on stable35 to a stable one (notifications#3306)
- Build(deps): Bump vue from 3.5.40 to 3.5.41 (notifications#3308)
office
- Chore(branchoff): Set version on stable35 to a stable one (office#138)
- Chore(deps-dev): Bump phpunit/phpunit from 10.5.63 to 10.5.64 in /vendor-bin/phpunit (office#140)
password_policy
photos
privacy
recommendations
related_resources
serverinfo
- Chore(CI): Adjust testing matrix for Nextcloud 35 on stable35 (serverinfo#1093)
- Ci: enable dependabot for npm dependencies (serverinfo#1096)
survey_client
suspicious_login
text
- Chore(CI): Adjust testing matrix for Nextcloud 35 on stable35 (text#9104)
- Fix(Table): return Tab and Shift-Tab handler results to mark the even… (text#9111)
twofactor_nextcloud_notification
- Chore(CI): Adjust testing matrix for Nextcloud 35 on stable35 (twofactor_nextcloud_notification#1471)
- Build(deps): Bump vue from 3.5.35 to 3.5.41 (twofactor_nextcloud_notification#1473)
