Search Progress Indicator Missing in Nextcloud Hub 9
    • 30.0.4
    • Ubuntu 20.04.6 LTS
    • nginx version: nginx/1.18.0 (Ubuntu)
    • 8.3
    • Yes
    • After update
    • Bare Metal/Archive
    • No - We using exclusively for internal.
Hi everyone,
We are using Nextcloud Hub 9, and our setup contains approximately 3.5 million files. When performing a search, it takes a significant amount of time for the results to appear, but there’s no visible progress indicator or feedback that the search is ongoing. This leads to user confusion as it seems like nothing is happening.
Has anyone encountered this issue or found a way to enable a search progress indicator? Any advice on optimizing search performance for such a large file base would also be appreciated.
Thanks in advance!
        "apps": [
                "path": "\/var\/www\/nextcloud\/apps",
                "url": "\/apps",
                "writable": true
        "dbtype": "mysql",
        "version": "30.0.4.1",
        "overwrite.cli.url": "https:\/\/cloud.pointcz.com",
        "dbport": "",
        "skeletondirectory": "",
        "filelocking.enabled": "true",
        "redis": {
            "port": 0,
            "timeout": 0,
            "dbindex": 9
        "mail_smtpmode": "smtp",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpport": "25",
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\PDF",
            "OC\\Preview\\Movie",
            "OC\\Preview\\SVG"
        "logtimezone": "Europe\/Prague",
        "preview_max_x": 1024,
        "preview_max_y": 768,
        "preview_max_memory": 512,
        "preview_max_scale_factor": 1,
        "trashbin_retention_obligation": "auto, 7",
        "default_language": "cs",
        "default_locale": "cs_CZ",
        "mail_sendmailmode": "smtp",
        "ldapIgnoreNamingRules": false,
        "mysql.utf8mb4": true,
        "theme": "",
        "log_type": "file",
        "logfile": "\/data\/nextcloud\/nextcloud.log",
        "loglevel": 3,
        "log_rotate_size": 10485760,
        "auth.bruteforce.protection.enabled": false,
        "integrity.check.disabled": false,
        "knowledgebaseenabled": false,
        "app_install_overwrite": [
            "openwebdavfolder",
            "hidesidebars"
        "activity_use_cached_mountpoints": true,
        "encryption.legacy_format_support": false,
        "encryption.key_storage_migrated": false,
        "addAllowedFrameAncestorDomain": "***",
        "default_phone_region": "CZ",
        "tempdirectory": "\/data\/temp",
        "onlyoffice": {
            "verify_peer_off": true,
            "jwt_secret": "***REMOVED SENSITIVE VALUE***",
            "jwt_header": "AuthorizationJwt"
        "maintenance_window_start": 2
  - activity: 3.0.0
  - admin_audit: 1.20.0
  - app_api: 4.0.3
  - bruteforcesettings: 3.0.0
  - checksum: 1.2.5
  - comments: 1.20.1
  - dav: 1.31.1
  - drawio: 3.0.3
  - federation: 1.20.0
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_external: 1.22.0
  - files_fulltextsearch: 30.0.0
  - files_linkeditor: 1.1.21
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_retention: 1.19.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - files_versions: 1.23.0
  - groupfolders: 18.0.8
  - hidesidebars: 2.2.5
  - logreader: 3.0.0
  - metadata: 0.21.0
  - notifications: 3.0.0
  - oauth2: 1.18.1
  - onlyoffice: 9.5.0
  - password_policy: 2.0.0
  - privacy: 2.0.0
  - provisioning_api: 1.20.0
  - qownnotesapi: 24.11.0
  - recommendations: 3.0.0
  - related_resources: 1.5.0
  - serverinfo: 2.0.0
  - settings: 1.13.0
  - sharebymail: 1.20.0
  - support: 2.0.0
  - text: 4.1.0
  - theming: 2.5.0
  - theming_customcss: 1.17.0
  - updatenotification: 1.20.0
  - user_ldap: 1.21.0
  - viewer: 3.0.0
  - workflowengine: 2.12.0
