Search for apps does not work (anymore)
  • Nextcloud Server version:
    • Nextcloud 32.0.3
    • #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16)
  • Web server and version:
    • Server version: Apache/2.4.65 (Debian)
  • Reverse proxy and version:
    • nginx version: openresty/1.27.1.2
  • PHP version:
    • PHP 8.3.29 (cli) (built: Dec 18 2025 21:15:07) (NTS)
    • yes
    • prob direct after installation
    • OMV Container
    • nope
        "version": "32.0.3.2",
        "loglevel": 3,
        "log_rotate_size": 262144,
        "maintenance_window_start": 3,
        "default_locale": "DE_CH",
        "default_phone_region": "CH",
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
        "dbtype": "mysql",
        "mysql.utf8mb4": true,
        "dbport": "",
        "htaccess.RewriteBase": "\/",
            "srv-nas-pi.kingma:8080",
            "office.kingma.ch",
            "office.king.ma"
        "overwrite.cli.url": "https:\/\/office.kingma.ch",
        "overwriteprotocol": "https",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smpttimeout": 30,
        "mail_smtpauth": true,
        "mail_smtpsecure": "ssl",
        "app_install_overwrite": []
  • activity: 5.0.0-dev.0
  • admin_audit: 1.22.0
  • bookmarks: 16.0.1
  • calendar: 6.1.2
  • circles: 32.0.0
  • comments: 1.22.0
  • contacts: 8.1.2
  • contactsinteraction: 1.13.1
  • cookbook: 0.11.5
  • dashboard: 7.12.0
  • dav: 1.34.2
  • documentserver_community: 0.2.1
  • federation: 1.22.0
  • files: 2.4.0
  • files_external: 1.24.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.1
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • firstrunwizard: 5.0.0-dev.0
  • groupfolders: 20.1.6
  • keeweb: 0.6.22
  • logreader: 5.0.0-dev.0
  • notes: 4.12.4
  • notifications: 5.0.0-dev.0
  • oauth2: 1.20.0
  • photos: 5.0.0-dev.1
  • privacy: 4.0.0-dev.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • richdocuments: 9.0.2
  • serverinfo: 4.0.0-dev.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • support: 4.0.0-dev.0
  • survey_client: 4.0.0-dev.0
  • systemtags: 1.22.0
  • text: 6.0.1
  • theming: 2.7.0
  • twofactor_totp: 14.0.0
  • updatenotification: 1.22.0
  • user_status: 1.12.0
  • viewer: 5.0.0-dev.0
  • weather_status: 1.12.0
  • webhook_listeners: 1.3.0
  • workflowengine: 2.14.0
  • app_api: 32.0.0 (installed 32.0.0)
  • encryption: 2.20.0 (installed 2.19.0)
  • fulltextsearch: 32.0.0 (installed 32.0.0)
  • onlyoffice: 9.12.0 (installed 9.12.0)
  • user_ldap: 1.23.0 (installed 1.22.0)
Trying to find an app from the appstore
  1. on the mean screen click the search icon
  2. Type “BrewMemo” in the unified search
  3. The app is not found
PASTE HERE
I have seen similar things on recent versions. Could you try to hide the search overlay and see if the “big list” in the background was filtered accordingly?
Just an idea
Chris
You first need to click on ‘Your apps’ or one of the categories in the sidebar on the left and then start typing the name in the search bar, because, unfortunately, it won’t find any apps from the ‘Discover’ page (or the ‘App bundles’ page, for that matter).
If I remember correctly, this issue has existed ever since the ‘Discover’ page was introduced because, before that, ‘Your apps’ was the App Store’s start page.
BTW, do you know if this is a formally reported bug, @bb77?
I think it’s [Bug]: Search for app in App section not working in "Discover" section · Issue #45558 · nextcloud/server · GitHub
